Dell sonicwall woes, unmatched mapping.
Discussion in '3CX Phone System - General' started by hogan71088, Sep 22, 2016.
  1. hogan71088
    Nov 30, 2015
    62
    Having great difficulty getting our dell sonicwall to correctly work with 3cx v15, have followed the 3cx guide and everything seems correct but getting an unmatched mapping on everything.
    Firmware version is: SonicOS Enhanced 5.9.1.7-2o
    Source port remap is disabled. Can anyone please help?
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
  3. hogan71088
    Nov 30, 2015
    62
    The hotfix according to dell support is included in the current firmware version...
  4. sjp_crs
    Sep 19, 2016
    34
    I can confirm 5.9.1.7-2o works fine. There is an addition setting you have to set tho.
    On the OUTBOUND rule, under the ADVANCED tab, you should have the 'Disable Source Port Remap' option checked.
    If that doesn't help, PM me and I'll shoot you some screenshots from my own setup that works fine now that I upgraded to 5.9.1.7-2o
  5. sjp_crs
    Sep 19, 2016
    34
    PM Sent - although it seems to be sat in the outbox...
  6. hogan71088
    Nov 30, 2015
    62
    Same here, feel free to post here if you can.
  7. sjp_crs
    Sep 19, 2016
    34
    Ok, lets see how this works ;)
    First I made sure the upgrade worked properly, and I was on the right firmware :
    Attachment_1
    Next, I created all the ports I needed in Firewall-Service Objects
    Attachment_2
    Then I added the ports to a Service Group to make life easier.
    Attachment_3
    I then created two NAT rules using the 'Create a Reflexive Policy' option on the first page. Make sure you CHECK the box, I took the screenshot and forgot to have it checked ;)
    Attachment_4
    Once the rules were complete, they look like this in the Nat Policies
    Outbound :
    Attachment_5
    Attachment_6
    Inbound :
    Attachment_7
    Attachment_8
    Once you apply the rules, check in the NAT-Policies list to ensure that your inbound/outbound NAT-Policies for 3CX occur BEFORE any general NAT policies - otherwise you'll never get to the 3CX one (Sonicwall does top-down processing, once it matches, it stops processing). So if you have a general outbound Any-Wan Primary IP NAT policy (which is pretty normal) then make sure your 3CX outbound policy occurs BEFORE the general one. Line 8 on my firewall has the 'disable source port remap' option set.
    7 Any - Original - Wan Primary IP - 3CX PBX - 3CX Ports - Original
    (Inbound, on the 3CX ports, forward to the PBX and leave the source IP and port unchanged)
    8 3CX PBX - WAN Primary IP - Any - Original - Any - Original
    (Outbound, from the PBX, translate the source to the WAN IP, leave the ports as is (Source Port remap disable))
    9 Any - Wan Primary IP - Any - Original - Any - Original
    (Outbound, Anything from any, Hide behind the WAN IP, leave the ports as is (but source port remap is allowed)
    I can now perform the firewall test without issue, and all ports come back Green.
    Let me know if that helps !!
    Steve
      File size:
      106.9 KB
      188
      File size:
      63.2 KB
      178
      File size:
      8.9 KB
      186
      File size:
      75.9 KB
      188
      File size:
      74.8 KB
      188
      File size:
      78.1 KB
      181
      File size:
      75.9 KB
      180
      File size:
      75.6 KB
      158
  8. hogan71088
    Nov 30, 2015
    62
    Thank you so much for taking time to post that.
  9. sjp_crs
    Sep 19, 2016
    34
    No problem - hopefully it gives you enough to get it working :)
  10. dirk02@stiegele.de
    Oct 21, 2009
    Thank you for bringing in the screenshots und descriptions.
    It helped me a lot!
    Thumbs up! :)
  11. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    30
    You also have to use the first static IP in your assigned block. Or at least up until a year ago. Wasted hours of my life troubleshooting that issue.
