Demo Expire?
Discussion in '3CX Phone System - General' started by jamesjfa, Mar 17, 2010.
  1. jamesjfa
    Mar 17, 2010
    This is my first post. I have had a look through but could not see the answer to this. I am about to install and configure 3CX for home use. Can anyone tell me does the demo key expire?
    I can't see pricing for home use and 2 calls would be enough for me anyway.
    Cheers,
    James
    10,863
    303
    Not that I'm aware of. Admin? If you want to upgrade to a newer version, later, which you probably will, you will require a new/different Demo code.
  3. jamesjfa
    Mar 17, 2010
    Thank you.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Yes that is correct demo keys do not expire. Also the demo keys are updated manually by the 3CX staff. Also due to the 2 call demo key limitation you will not be able to transfer calls.
