Deploying 3CX MyPhone on Terminal Server
Discussion in '3CX Phone System - General' started by AragornEstel, May 21, 2011.
  1. AragornEstel
    May 21, 2011
    How would you approach deploying the MyPhone on the Terminal Servers, so that it's loaded when a user logs in?
    Would each user need to visit the web based MyPhone and install one by one, or can it be deployed in any other way?
    Thanks in advance - love 3CX :)
    Best regards,
    Mike
  2. FBW
    FBW New Member
    Nov 19, 2008
    108
    I think it's not available yet for v10.
    Of course you could add the URL to the startup.
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Works fine on terminal server, we did a large install last week
    Log on to Terminal Server and install the MyPhone via the URL, install desktop components etc and setup for 1 user.
    Now when installing for each additional user, all you need to do is visit the url and configure, no need to install desktop components again, which saves a lot of time.
    Once you configured the first MyPhone, each additional install only takes a couple of minutes at most.
  4. netswork
    netswork Active Member
    Mar 11, 2011
    577
    We tested this on our internal Terminal server and it works fine. Just like David said in his post.
    I have seen another post of people having trouble if you have multiple citrix/terminal servers in a load balanced setup. We dont have any customers large enough to need more than one terminal/citrix server so its not an issue for us. They same guy was also having issues with roaming profiles and the myphone app working correctly.
  5. kylejoe1
    Feb 15, 2011
    66
    May want to see this thread:
    http://www.3cx.com/forums/terminal-server-myphone-reinstall-via-browser-after-logoff-20977.html#p106423
  6. gfischer
    Sep 19, 2011
    is it now possible , to use the tapi funktion out of outlook 2003 with the myphone desktop components on a Terminal-Server (2008 R2) `?
