Deployment Machine
Discussion in '3CX Phone System - General' started by AlexanderHanna, Jan 7, 2016.
  1. AlexanderHanna
    AlexanderHanna New Member
    Oct 2, 2015
    100
    12
    Hi, I’m curious to know what machines others are using for their 3CX deployment. In my case, where a client has a VM, I will deploy to it. However, I’m trying to find a reliable machine that will work for non VM environments.
    Thank you.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,380
    84
    The V14 manual does have some information including minimum hardware requirements here: http://www.3cx.com/docs/installing-3cx/#h.5hoy5wwhhk5c
  3. AlexanderHanna
    Oct 2, 2015
    100
    12
    Thank you for your reply. However, I'm aware of the minimum hardware requirements. What I'm looking for is machine name/brand information that others might be using in production.
  4. snowsam
    May 26, 2011
    79
    We have used the medium-low end pizza box 1U rack servers from Dell. Loading it with free vmware and then using the on-board storage allows for upgrading down the road without having to totally reload. When we have time, we have had good luck buying from the Dell Business Outlet site. About every month they have a coupon that lowers the price even more and the warranty is the same as buying new.
  5. AlexanderHanna
    Oct 2, 2015
    100
    12
    Thank you Snowsam!
    I will check it out.
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    I've used a SuperMicro (running 2012 essentials) and also a Mac Mini (running Bootcamp - an 80 phone installation with VM)...
