Deregistering after a couple of minutes
Discussion in 'Android' started by GonzaloS, Feb 2, 2018.
  1. GonzaloS
    Feb 2, 2018
    11
    I am able to connect to the server but if I don't keep the app open as soon as it goes to the background it gets disconnected from the server.
    I set up the configuration to stay alive in the background yet it does not.
    Any idea how to keep the app alive?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    Hello @GonzaloS,
    I suggest to delete that extension and recreate it again with all the appropriate setting.
    Thank you
