Designer location
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Aug 29, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I've found I can't debug when the voice application designer is not on the actual 3cx server. Am I missing something?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    In order to debug a callflow you need to:
    1) Deploy the debug configuration of the callflow.
    2) Make a call to the callflow. This will cause that the callflow generates a debug information file when the callflow is executed.
    3) Start a debug session, select the generated debug information file, and advance the callflow step by step.
    Also, note that when you make any change to the callflow, the "start debug" menu option will be disabled. You need to build the callflow, deploy and debug, without making any change to the callflow.
    Debug can be done local to the 3CX server or in any remote computer. Please verify that the previous steps are being done and that the callflow has not been modified.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    OK, it seems ok now.
