Desk phone recommendations
Discussion in '3CX Phone System - General' started by mdoke, Feb 21, 2010.
  1. mdoke
    Jan 26, 2010
    I have a 32 line version of 3CX.
    Need to convert about 20 users from the soft phones to desk phones.
    Most users need the ability to 3 way conf and that is about the extent of "advanced" features they need.
    Anyone have experience with the following phones and recommend any others (that don't break the bank!).
    Polycom 331
    Cisco SPA502G or SPA504G
    Cisco SPA941
    Any experience is appreciated....
  2. pjr
    pjr New Member
    Oct 5, 2009
    154
    We use Polycom 331's and they are great but the speed dial provisioning in 3CX at present can cause the screen to look a little odd - ie they have 2 lines and you can only provision one by 3CX, so the 2nd line automatically defaults to be a speed dial for the first entry in the phone book - looks a little odd and is a pain to turn off but it can be done.
    Apart from that quibble they are great phones and dead easy to provision using DHCP option 66
    Paul
  3. mhanson
    mhanson New Member
    Nov 6, 2008
    186
  4. mdoke
    Jan 26, 2010
    Thanks for the tips!
