Desk phones un-register if Android client connects
Discussion in '3CX Phone System - General' started by Vahur, Jan 20, 2017.
  1. Vahur
    Jan 20, 2017
    10
    We are running 3CX 15 pro, sp4. I've noticed if a user connects with an Android phone using the 3CX app the desk phone (Aastra 6735i) becomes unregistered after a few minutes. If the Android app is shutdown the user's desktop phone becomes registered again after 5 - 10 minutes.
    Exact same problem without any answer was actual already several years ago: https://www.3cx.com/community/threa...if-android-client-connects.38841/#post-159711
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Hello @Vahur
    Are these local extensions? what firmware are you running and what template did you use to provision the phones?
    We have not come across this issue before and the client should run independent from the IP phone. Is the issue happening only with the client?
    What if you add another ip phone onto the same extension? does the issue happen then?
  3. leejor
    11,291
    361
    What does the 3CX Activity log show when this event occurs? Are there any errors? Is there an apparent conflict (port?) between the two devices?
  4. Vahur
    Jan 20, 2017
    10
    Aastra is in local network, I have tested with all available firmware versions. Using 3CX from PC has no such kind of effect. From Aastra web interface I see error on System information - SIP Status - Contact Mismatch during No Service message on phone screen. On PBX side (192.168.2.115 - Aastra 6735i deskphone, 192.168.2.106 - Android with 3CX client, starting from activating 3CX on Android to No Service message on Aastra):
    01/24/2017 10:31:06 AM - Endpoint Extn:726 has refreshed contact <sip:726@127.0.0.1:5488> for device Dev(746865335):[sip:726@127.0.0.1:5488;rinstance=f4df8d4d3237a539 / 726]
    01/24/2017 10:31:03 AM - Endpoint Extn:726 has refreshed contact <sip:726@192.168.2.115:5060> for device Dev(506270536):[sip:726@192.168.2.115:5060 / 726]
    01/24/2017 10:30:52 AM - Endpoint Extn:726 has removed contact <sip:726@192.168.2.106:50195>
    01/24/2017 10:30:52 AM - [CM504002]: Endpoint Extn:726: a contact is unregistered. Contact(s): [sip:726@127.0.0.1:5488 / 726,sip:726@192.168.2.115:5060 / 726,sip:726@192.168.2.60:60530 / 726,sip:726@192.168.2.106:45577 / 726]
    01/24/2017 10:30:52 AM - Settings of Extn:726 has been updated
    01/24/2017 10:30:52 AM - OverrideExt.726 has inactive profile override
    01/24/2017 10:30:52 AM - MWI Extn:726: sending to sip:726@192.168.2.106:50195;transport=TCP;rinstance=1-ocs3pz.bji3n-f4sqhdyfio2wiiugiia;ob;inst="f3ada8d7"; new=0; total=0
    01/24/2017 10:30:52 AM - Endpoint Extn:726 has added contact <sip:726@192.168.2.106:50195> for device Dev(537024732):[sip:726@192.168.2.106:50195;transport=TCP;rinstance=1-ocs3pz.bji3n-f4sqhdyfio2wiiugiia;ob;inst="f3ada8d7" / 726]
    01/24/2017 10:30:52 AM - [CM504001]: Endpoint Extn:726: new contact is registered. Contact(s): [sip:726@127.0.0.1:5488 / 726,sip:726@192.168.2.106:50195 / 726,sip:726@192.168.2.115:5060 / 726,sip:726@192.168.2.60:60530 / 726,sip:726@192.168.2.106:45577 / 726]
    01/24/2017 10:30:52 AM - MWI Extn:726: sending to sip:726@192.168.2.106:45577;rinstance=0-btnvz8eqlvxtzgjygapbsoocj7hiv1oq;ob;inst="f3ada8d7"; new=0; total=0
    01/24/2017 10:30:52 AM - Endpoint Extn:726 has added contact <sip:726@192.168.2.106:45577> for device Dev(161431203):[sip:726@192.168.2.106:45577;rinstance=0-btnvz8eqlvxtzgjygapbsoocj7hiv1oq;ob;inst="f3ada8d7" / 726]
    01/24/2017 10:30:52 AM - [CM504001]: Endpoint Extn:726: new contact is registered. Contact(s): [sip:726@127.0.0.1:5488 / 726,sip:726@192.168.2.115:5060 / 726,sip:726@192.168.2.60:60530 / 726,sip:726@192.168.2.106:45577 / 726]
    At the moment problem was minimized with set Registration Failed Retry Timer to minimum, 30 sec. Default was 1200, so I get only a 30 sec blackout compared to 20 min. Another solutions seem to be use those phones with user who has no Android client.
  5. leejor
    11,291
    361
    Not familiar with an "Inactive profile override"
    Is that an option assigned to that particular extension?
  6. Vahur
    Jan 20, 2017
    10
    I'm not sure, what it is, but it seems to do something with all extension. Example of another user, with Android and Windows clients:
    01/24/2017 11:04:36 AM - Call to T:Extn:716@[Dev:sip:716@192.168.2.146:1743;rinstance=0-a7e0b0da897c4f0ca2fd42b4b51211f4;ob,Dev:sip:716@192.168.2.117:52046;rinstance=0-gqtvv9aws6twpgqzacewspuheebvpdpq;ob;inst="31393ff8",Dev:sip:716@127.0.0.1:5488;rinstance=6e82b0e7506a7379] from L:110.1[Line:10001<<+3726300531] failed, cause: Cause: 408 Request Timeout/INVITE from 127.0.0.1:5488
    01/24/2017 10:41:02 AM - Endpoint Extn:716 has refreshed contact <sip:716@127.0.0.1:5488> for device Dev(1728318382):[sip:716@127.0.0.1:5488;rinstance=6e82b0e7506a7379 / 716]
    01/24/2017 10:40:07 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.117:52046> for device Dev(959777914):[sip:716@192.168.2.117:52046;rinstance=0-gqtvv9aws6twpgqzacewspuheebvpdpq;ob;inst="31393ff8" / 716]
    01/24/2017 10:40:07 AM - Settings of Extn:716 has been updated
    01/24/2017 10:40:07 AM - OverrideExt.716 has inactive profile override
    01/24/2017 10:40:03 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.146:1743> for device Dev(616508521):[sip:716@192.168.2.146:1743;rinstance=0-a7e0b0da897c4f0ca2fd42b4b51211f4;ob / 716]
    01/24/2017 10:39:14 AM - Endpoint Extn:716 has refreshed contact <sip:716@127.0.0.1:5488> for device Dev(1728318382):[sip:716@127.0.0.1:5488;rinstance=6e82b0e7506a7379 / 716]
    01/24/2017 10:38:12 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.117:52046> for device Dev(959777914):[sip:716@192.168.2.117:52046;rinstance=0-gqtvv9aws6twpgqzacewspuheebvpdpq;ob;inst="31393ff8" / 716]
    01/24/2017 10:38:12 AM - Settings of Extn:716 has been updated
    01/24/2017 10:38:12 AM - OverrideExt.716 has inactive profile override
    01/24/2017 10:38:08 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.146:1743> for device Dev(616508521):[sip:716@192.168.2.146:1743;rinstance=0-a7e0b0da897c4f0ca2fd42b4b51211f4;ob / 716]
    01/24/2017 10:37:25 AM - Endpoint Extn:716 has refreshed contact <sip:716@127.0.0.1:5488> for device Dev(1728318382):[sip:716@127.0.0.1:5488;rinstance=6e82b0e7506a7379 / 716]
    01/24/2017 10:36:16 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.117:52046> for device Dev(959777914):[sip:716@192.168.2.117:52046;rinstance=0-gqtvv9aws6twpgqzacewspuheebvpdpq;ob;inst="31393ff8" / 716]
    01/24/2017 10:36:16 AM - Settings of Extn:716 has been updated
    01/24/2017 10:36:16 AM - OverrideExt.716 has inactive profile override
    01/24/2017 10:36:12 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.146:1743> for device Dev(616508521):[sip:716@192.168.2.146:1743;rinstance=0-a7e0b0da897c4f0ca2fd42b4b51211f4;ob / 716]
    01/24/2017 10:35:36 AM - Endpoint Extn:716 has refreshed contact <sip:716@127.0.0.1:5488> for device Dev(1728318382):[sip:716@127.0.0.1:5488;rinstance=6e82b0e7506a7379 / 716]
    01/24/2017 10:34:21 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.117:52046> for device Dev(959777914):[sip:716@192.168.2.117:52046;rinstance=0-gqtvv9aws6twpgqzacewspuheebvpdpq;ob;inst="31393ff8" / 716]
    01/24/2017 10:34:21 AM - Settings of Extn:716 has been updated
    01/24/2017 10:34:21 AM - OverrideExt.716 has inactive profile override
    01/24/2017 10:34:17 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.146:1743> for device Dev(616508521):[sip:716@192.168.2.146:1743;rinstance=0-a7e0b0da897c4f0ca2fd42b4b51211f4;ob / 716]
    01/24/2017 10:33:48 AM - Endpoint Extn:716 has refreshed contact <sip:716@127.0.0.1:5488> for device Dev(1728318382):[sip:716@127.0.0.1:5488;rinstance=6e82b0e7506a7379 / 716]
    01/24/2017 10:32:26 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.117:52046> for device Dev(959777914):[sip:716@192.168.2.117:52046;rinstance=0-gqtvv9aws6twpgqzacewspuheebvpdpq;ob;inst="31393ff8" / 716]
    01/24/2017 10:32:26 AM - Settings of Extn:716 has been updated
    01/24/2017 10:32:26 AM - OverrideExt.716 has inactive profile override
    01/24/2017 10:32:22 AM - Endpoint Extn:716 has refreshed contact <sip:716@192.168.2.146:1743> for device Dev(616508521):[sip:716@192.168.2.146:1743;rinstance=0-a7e0b0da897c4f0ca2fd42b4b51211f4;ob / 716]
    01/24/2017 10:31:59 AM - Endpoint Extn:716 has refreshed contact <sip:716@127.0.0.1:5488> for device Dev(1728318382):[sip:716@127.0.0.1:5488;rinstance=6e82b0e7506a7379 / 716]
    01/24/2017 10:30:31 AM - Settings of Extn:716 has been updated
    01/24/2017 10:29:49 AM - Leg L:99.1[Extn:716] is terminated: Cause: CANCEL from 192.168.2.146:13759
    01/24/2017 10:29:03 AM - Call to T:Line:10001>>531@[Dev:sip:sip.P01586305@pbx.elion.ee:5060] from L:98.1[Extn:716] failed, cause: Cause: 480 Temporarily not available/INVITE from 217.159.187.68:5060
