Deskphone calling itself - Showing as unprovsioned
Discussion in '3CX Phone System - General' started by Cajun McCartney, Apr 2, 2018.
  1. Cajun McCartney
    Dec 15, 2017
    19
    I setup a Grandstream GXP2135 to test out the new phone system. Everything works great; incoming and outgoing calls all work, but having two issues.
    1. The phone will randomly start getting a call from it's own extension. For example. shortly after configuring extension 7108 on the phone it started ringing with a call from 7108 (it's own extension) and when picking up, it's silent. Nothing shows in the call logs for this number in the consoles. Happens randomly.
    2. In the management console when I find the phone in the Phones section, under MAC Address it shows as "Unprovisioned" and the options for it are grayed out. Not sure if this is related to issue 1 or if this is even an issue at all. Just suspect that this should be showing as provisioned since its working properly.
    Thank you.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,577
    209
    Although you probably get this randomly enough that it is hard to capture, it would be great to see a wireshark trace of this issue to see what is going on.
    As for your "UNPROVISIONED" issue I get exactly the same with multiple manufacturers of "supported" phones (snom & Yealink). Even when they are provisioned locally, running supported firmware with standard templates (no customization).
