Deskphone mode and TAPI
Discussion in 'Windows' started by uncletom, Aug 7, 2008.
  1. uncletom
    Aug 7, 2008
    Hello
    I got a question regarding the VoIP client and its Tapi driver.
    If I use the 3CX-VoIP client as Softphone (registered as a completly new extension on the 3CX PBX-Server) the TAPI driver works flawlessly, meaning I get two popups
    1- from the 3CX- VoIP client
    and
    2- from my third party software (BlueOffice,which is basically a database system for adresses, contact information etc.)
    However, if i use the 3CX VoIP client in Deskphone mode, (registered on/as the same extension as my Deskphone),
    theres an error and TAPI gives out "DN" as caller ID in BlueOffice, still the number on the popup from 3CX-client shows the correct number.
    I think this has to do with shared lines.
    I would like however to use the 3CX VoIP client in deskphone mode, placing calls to/with my Deskphone from my PC, and if somebody calls see their contact information pop-up in BlueOffice.
    Any tip, getting this to work, would be appreciated.
    Best regards
    Tom
  2. uncletom
    Aug 7, 2008
    hi matt
    thanks for replying
    guess I have to wait and use either function seperately.
    hope the guys at 3cx will fix tapi in the next release.
    till then
    tom
