Desktop Components
Discussion in '3CX Phone System - General' started by onecg, Apr 26, 2011.
  1. onecg
    Apr 14, 2011
    Hi Guys
    I cannot see the install button when going to myphone I have the RC of V10
    Any help would be great
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    You need to install MyPhone locally first then the install button will show up. Right click anywhere in the MyPhone user console then select "Install 3CX MyPhone locally" follow prompts, login to the local installation via the icon on your desktop and then browse to the install desktop components.
    Good luck.
