destination is not available...
Discussion in '3CX Phone System - General' started by nashakhalov, Dec 9, 2009.
  1. nashakhalov
    Nov 23, 2009
    10
    If calling to a mobile phone that is switched off users hear: destination is not available not registered or no route available. Is there any option to hear GSM carrier message instead?
    11,111
    329
    That probably depends on whether you are going out over a VoIP provider or a gateway and where the recording that you hear is originating. If you are using a VoIP provider and they get a certain message back from the mobile company then that is the recording that they provide to the caller.
