16-avr.-2015 17:43:58.390 Leg L:1.1[Extn] is terminated: Cause: BYE from PBX
16-avr.-2015 17:43:58.354 [CM503020]: Call(C:1): Normal call termination. Call originator: Extn:501. Reason: Not found
16-avr.-2015 17:43:58.354 [CM503014]: Call(C:1): No known route from Extn:501 to target: <sip:[email protected]:5060>
16-avr.-2015 17:43:58.354 Call(C:1): from Extn:501 to +3212345678 doesn't match any outbound rule. No outbound rule could be selected.
16-avr.-2015 17:43:58.354 [Flow] Target endpoint for +3212345678 can not be built!
16-avr.-2015 17:43:58.351 [CM503001]: Call(C:1): Incoming call from Extn:501 to <sip:[email protected]:5060>
No, delete +, only 00athena said:International Dial Code : 00, +
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
