destination not found
Discussion in 'Windows' started by riz21, Apr 30, 2012.
  1. riz21
    Apr 30, 2012
    hi i have just downloaded this 3cxPhone and i am registered with freetring.com which provides sip server i have credit . i cannot make outbound calls whenever i try to dial a number it immediately says destination not found. i dnt know how to solve this issue can some body help me. i have tried to change settings but it doesnot work.
    thanks
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    have you asked them if you can use software besides what they offer?
  3. leejor
    11,095
    327
    What is saying "destination not found"? The 3CX phone display or a recording from the provider?
    if it's the provider, then be sure that you are sending digits in the correct format (length/prefix). Some VoIP providers deal with customers from all over the world and expect digits in an "international" format.
    From what I can tell from their web site, they expect calls in the format...011 7 495 1234567
    So, 011 country code, city code, number
  4. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    You must probably sent number in internacional format (e164), but first do you have outbound rule for that sip trunk?
