Detecting handsets when using 3CX in the cloud
Discussion in '3CX Phone System - General' started by PreviouslyAsterisk, Jul 21, 2017.
Tags:
  1. PreviouslyAsterisk
    Jun 26, 2017
    32
    We've got a local 3CX server and are now experimenting with 3CX on a remote server.
    Locally, phones are discovered by 3CX and can be assigned to an extension. However, remotely, since the phones are the wrong side of the router, they won't be discovered.
    What's the 3CX cloud way of discovering phones on a network? Is an agent installed somewhere this side of the border to discover phones and report to 3CX in the cloud? Or must each phone be manually provisioned?
    Any advice appreciated :D
  2. teldata1
    Aug 24, 2015
    63
    Using an SBC at the remote site will make the phones appear in the phone page!
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,613
    243
    Or if they are the recommended phones (like Yealink) and you configure them as STUN they will RPS which is a fancy way of saying they will find the server automatically if you factory default them. Provided you are on reasonably current firmware
  4. OCWI
    OCWI New Member
    Jan 17, 2017
    161
    46
    The best is going to be with a BSC (Border Session Controller).
    We recommend using a raspberry pi. Cheap and effective. Much more reliable than its windows counterpart.
