"Device not identified:User Agent not matched"
Discussion in '3CX Phone System - General' started by smcmullan, Dec 8, 2009.
  1. smcmullan
    Dec 8, 2009
    I'm new to 3cx, but not to telephony.
    Just installed the latest 3cx phone system and skype gateway, to kick the tires.
    internal extensions work fine.
    Skype config looks like it went OK; gateway is OK, status is registered. But when I try to place a call, it fails. Log are included below.
    calling rule is simple; apply rule to calls that start with 9, strip 1 digit, use the skype trunk.
    I have dial-out with skype; I can dial outgoing 10-digit calls directly from the skype client and it works.
    I read on the forums to try making the skype channel not a master, but that doesn't change the behavior I see.
    Versions and logs included below.
    Any idea what I can do to make this work?
    Thanks!
    --Scott
    Skype client version: 4.1.0.179
    Skype gateway version: 2.0.9919.0
    3cx version: 8.0.10116.583
    21:02:43.262 [CM503008]: Call(11): Call is terminated
    21:02:43.251 [CM503020]: Normal call termination. Reason: Not available
    21:02:43.251 [CM503016]: Call(11): Attempt to reach <sip:98005551212@192.168.100.20:5060> failed. Reason: Temporarily Unavailable
    21:02:43.250 [CM503003]: Call(11): Call to sip:8005551212@127.0.0.1:6060 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6060
    21:02:43.248 [CM505002]: Gateway:[Skype] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10000@127.0.0.1:5060]
    21:02:43.248 [CM503002]: Call(11): Alerting sip:10000@127.0.0.1:6060;rinstance=c898f6e8d0204dc6
    21:02:43.094 [CM503025]: Call(11): Calling PSTNline:8005551212@(Ln.10000@Skype)@[Dev:sip:10000@127.0.0.1:6060;rinstance=c898f6e8d0204dc6]
    21:02:43.050 [CM503004]: Call(11): Route 1: PSTNline:8005551212@(Ln.10000@Skype)@[Dev:sip:10000@127.0.0.1:6060;rinstance=c898f6e8d0204dc6]
    21:02:43.048 [CM503010]: Making route(s) to <sip:98005551212@192.168.100.20:5060>
    21:02:43.044 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 4.0.9878.0] PBX contact: [sip:100@192.168.100.20:5060]
    21:02:43.038 [CM503001]: Call(11): Incoming call from Ext.100 to <sip:98005551212@192.168.100.20:5060>
  2. smcmullan
    Dec 8, 2009
    Just found the "trace logs" in the skype gateway. Partial log included, in case it helps.
    Is this trying to call an account instead of a phone line? That might make some sense of it... but I need to know how to dial out to a phone line.
    21:36:20:354 - Info : Processing Skype attach request
    21:36:20:363 - Info : Skype attach succeeded
    21:36:20:366 - Info : Waiting for Skype authorization
    21:36:31:491 - Info : Skype connection status is ONLINE
    21:36:31:500 - Info : Expected Skype user logged in: [**redacted**]
    21:36:31:505 - Info : Skype user status is ONLINE
    21:36:31:510 - Info : Skype authorization request succeeded
    21:38:10:181 - Info : Incoming call from PBX ringing
    21:38:10:181 - Info : Outbound call requested
    21:38:10:181 - Info : Creating a Skype call to account [8005551212]
    21:38:10:186 - Error : Exception: Skype call creation failed for [8005551212]: CALL: Unrecognised identity
    21:38:10:186 - Info : PBX call has been ended by PBX
  3. smcmullan
    Dec 8, 2009
    OK, never mind, looks like I got it to dial.
    Didn't realize I needed to give this a country code; once I changes the dial rule to also append 001, my 10-digit dialing went through OK.
