DHCP Option 66 - Cisco Routers
Discussion in '3CX Phone System - General' started by mazhar, Jul 4, 2011.
  1. mazhar
    Apr 27, 2010
    10
    Can anyone help me in configuring the DHCP option 66 to auto provision url during dhcp lease on CISCO ROUTERS.
  2. danoh
    Aug 18, 2010
    56
    Assuming you already have the dhcp pool setup.
    For the sake of example, we'll say it's called "DHCPPOOL"
    ip dhcp pool DHCPPOOL
    option 66 ascii "http://whatever.you.want.here/"
    If you have trouble with the device not picking up the option 66, it could be because of the quotes. Try removing them like:
    no option 66 ascii "http://whatever.you.want.here/"
    option 66 ascii http://whatever.you.want.here/
  3. mazhar
    Apr 27, 2010
    10
    Thank you for the post. I tried the option 66 as specified in your post. It doesn't work. I checked it on Cisco 1841, Cisco 837 routers. May be it takes only the IP address for the TFTP server and it doesn't work for a URL.
