DHCP Server for XP?
Discussion in '3CX Phone System - General' started by KerryG, Nov 10, 2009.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Has anyone found a good little DHCP server that can run on Windows XP? The few I have found don't support pushing DHCP scope options and that is a requirement for auto-provisioning.
  2. comresource
    comresource Member
    May 22, 2009
    303
  3. KerryG
    Jun 19, 2009
    960
    TFTP32 only supports 1 DHCP Scope Option and doesn't support reservations. Cisco phones require DHCP Option 156 and 160 and I like having reservations for some systems so TFTP32 is not adequate.
  4. comresource
    comresource Member
    May 22, 2009
    303
    It certainly does support option 66 and static reservations. You have to edit the .ini or registry depending on how you installed it.
  5. StefanW
    Jun 2, 2009
    1,222
    93
    http://www.softcab.com/dhcp-server/index.php
    does everything in 1 min set up
  6. KerryG
    Jun 19, 2009
    960
    Again, the issue with TFTP32 is it only allows for ONE DHCP Scope option, that is not sufficient if you are going to have mixed phones that include the Cisco SPA5xx and any other brand.
    Nowhere in the softcab site does it mention being able to set DHCP Scope options
  7. comresource
    comresource Member
    May 22, 2009
    303
    You can add multiple options via registry or .ini
    From the FAQ
    Code:
    Q: Does the DHCP server manages other options ?
    A: Yes. You have to edit either the registry or the Ini file and change the AddOptionNumber<N> and AddOptionValue<N>. The values are string values unless they begin whith 0x followed by a hexadecimal value. Note that the special string '$IP$' will be replaced by the assigned IP address.
    .ini Example :
    AddOptionNumber1=66
    AddOptionValue1=192.168.44.2
    AddOptionNumber2=67
    AddOptionValue2=pxegrub_rtl8139
    AddOptionNumber3=150
    AddOptionValue3=menu-nb.lst
  8. KerryG
    Jun 19, 2009
    960
    Thanks Danny,
    Considering I am trying to pull out a Linux box as my main DHCP server I guess editing .ini files isn't completely horrible since I had no UI for that dhcp config file there.
  9. comresource
    comresource Member
    May 22, 2009
    303
    I wont argue its ugly but it works and the price is right.
  10. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    I've used a product called DHCP Turbo on XP and it works very well.
    I think that you need to pay for it but there is a demo.
  11. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
  12. KerryG
    Jun 19, 2009
    960
    Do any of you do auto-provisioning of phones? To do that you need a tftp server that can serve out scope options. the one from softcab can not. The other guys are right, tftpd32 is the best choice so far and you just have to edit the ini file in order to have multiple scope options and reservations. It may not be super easy to use because of that but it is a completely usable solution.
