DHCP server with Option 66
Discussion in '3CX Phone System - General' started by RichardCrabb1, Oct 18, 2010.
  1. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    Hanewin is a DHCP server that runs on Windows. What is key is that it supports options such as Option 66 - to point to the 3CX to allow the location for http configuration. It is quite sophisticated and will take the place of a Microsoft DHCP server, if the environment does not have access to such a server.
    Richard Crabb
  2. varietel
    Oct 29, 2010
    22
    Hi Richard,
    I am struggling with Tftpd32 DHCP server for Windows to provision Polycom 430 phoones. After installing it does not have the option 66 setup but you have to change the .ini file to get that. I did that but as of now still can not get the provisioning from 3CX. The phone still loading the existing configuration. You can follow this link:
    http://www.3cx.com/forums/dhcp-server-for-xp-12322.html
    for more information on the Tftpd32. Let me know if use this and get it working.
    Regards,
    Iraj Partovi
    Varietel Communications.
    801-889-1414
    ipartovi@varietelcom.com
