Diagnose issues with 3CX SBC
Discussion in '3CX Phone System - General' started by Philip Darnell, Oct 17, 2017.
  1. Philip Darnell
    Philip Darnell New Member
    Jan 26, 2017
    132
    10
    I have just installed a 3CX SBC on Raspberry Pi with 20 extensions, I am having a couple of issues with the voice cutting out for literally a split second, it happens probably once per call, and they miss about 1/4 of a word.
    I have listened to the call recordings on the hosted server and there is no issue with the recording, so it is when it is coming into the remote network. I have QoS setup TCP / UDP on port 5090 for the SBC, Do I need to specify any QoS on the phones?
    How do I diagnose voice issues on the Raspberry Pi SBC?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,381
    278
    Hello @Philip Darnell
    depending on the phones you have you could run a pcap on the phones to see if the audio reaches the phone broken or perhaps it is the handset that causes the small cut off. You could also run a pcap on the Raspberry PI and compare the audio.
  3. Philip Darnell
    Jan 26, 2017
    132
    10
    I would suspect it is an issue with the call coming from the remote router to the SBC, how can I run PCAP on the Raspberry Pi? It doesn't happen on every call so will need to leave it running for about 30 mins, or is this not recommended?
  4. StefanW
    Jun 2, 2009
    1,198
    79
    an PI is not capable for running a Pcap for that long and will cause false errors while executing.
  5. superior1
    Apr 11, 2011
    32
    You could install a dummy hub in front of any of the phone, SBC, firewall and run wireshark. Its kind of a pain in the butt, but it will work.Then on the wireshark specify in the capture setting the IP addresses you are monitoring.
  6. Philip Darnell
    Jan 26, 2017
    132
    10
    Thanks for the reply.
    I'm very new to using wireshark so not got a vast knowledge on how to use it. Are you saying install wireshark on a dummy PC on the network, run wireshark on that PC and specify the IP Address of the SBC and it will capture the traffic to that IP?
  7. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Devices that are real hubs; convenient for capturing:confused:
  8. Philip Darnell
    Jan 26, 2017
    132
    10
    Thanks, I've made some changes to the QoS so hopefully that helps.
    Also ordered a second broadband to run the phones seperate from the data but will take 2 weeks before installed.
  9. YiannisH_3CX
    May 10, 2016
    4,381
    278
    Please keep us updated with the results
  10. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    170
    59
    do an "apt-get install htop" and then as SU run htop. It will show you if the PI is stressed. 20 phones is possible but you're approaching the edge of the PI's happy zone. Consider using any Intel-based platform with Debian for an SBC. The PI is wonderful but its more of a pony than a horse.
  11. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,253
    63
    The actual problem with the Pi I remember reading about is the way the LAN port is connected. Apparently on the chip it is connected to the USB 2.0 chip, so even though it is a 100MBit port, realistically it is much less. I was also mentioned that when faced with high traffic, it may cause dropped packets which for other non-real time applications might be OK, for VoIP it's not.
    I completely agree with @DSXDATA but for a slightly different reason, 20 phones is reaching the Pi's "happy zone".
  12. Philip Darnell
    Jan 26, 2017
    132
    10
    Thanks for this I will try it. They don't have a massive volume of calls, with the 20 phones there are probably only 4 sim calls at any time, so I would have thought the Pi was sufficient.
    When digging further I realised the issue was calls between sites, Site A (Has the Pi SBC) Site B (setup as STUN), because there was VPN connection between the two sites, I think the phone was trying to deliver the audio itself because obviously it knew the address of the other phone. I have now enabled 'PBX delivers Audio' for Site B that is STUN and it seems to be alright.
    NickD_3CX likes this.
  13. Philip Darnell
    Jan 26, 2017
    132
    10
    I ran htop and attached the screenshot, to me it looks like it is coping fine?
    Still having some audio issues
  14. Philip Darnell
    Jan 26, 2017
    132
    10
    They do have some Yealink W52Ps there which they have never had an issue with, the issue seems to persist on the Yealink T27G.
    When I look on the account on the phone the Yealink W52P are setup slightly different, Server IP is the SBC local IP and then the proxy server is the SBC local IP, whereas the T27Gs server IP is the FQDN and then the proxy server is the SBC local IP.
    Is this right?
  15. NickD_3CX
    Jun 2, 2014
    1,253
    63
    Although both work (at least for now), the correct is that of the T27. I don't think though this is what is causing the audio problems.
    The interesting though is that the issue happens only on calls between the 2 sites. "PBX Delivers Audio" for all remote STUN extensions was the right thing to do, I personally recommend always doing this as it shouldn't work in another way anyway, this way you just ensure that it does.
    To try now and isolate where the problem is call *777 from an extension that goes through the SBC. The user should hear their voice back of whatever they say. Ask them to check check if the audio is being sent back to them in tact.
    Then do the same with the remote STUN extension.
    This ways you can "split" the call and check the call quality SBC <----> PBX and PBX <----> STUN separately, then know which part to focus on.
  16. Philip Darnell
    Jan 26, 2017
    132
    10
    The W52P was setup by copying the Provisioning link, whereas the T27G were setup from the management console, so I assume thats why it's worked like that.
    I will get them to try the *777 from both sites and see how it goes.
  17. Philip Darnell
    Jan 26, 2017
    132
    10
    If they dial *777 from behind the SBC, will the audio be delivered by the server or just go to the SBC and then back to the phone?
