Dial by first or last name
Discussion in '3CX Phone System - General' started by telcom2, Jan 14, 2013.
  1. telcom2
    Feb 1, 2012
    I have a customer that wants to be able to have someone enter the first few letters of a users first or last name to find them in the directory.
    We have devised a work-a-round where we created an additional extension for each user, then reversed the first/last name. We then have the "dummy" extension forward permanently to the real extension. The last piece of this is to change the prompt UserName.wav to reflect the ability to enter a few letters of the first or last name.
    Has anyone been successful replacing a prompt file? (We are having trouble recording at a high enough quality to match the built-in prompts.)
    Any suggestions?
    Thank you,
    Kevin Bouchonnet
    TelcomData, LLC
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try this reader (and replace text with what what you want):
    http://www.linguatec.de/vrweb/popup1_ptonline?dir=0&srctext=Hello,%20please%20dial%20extension%20number&lang=EG&guilang=en&readcontent=all&srctype=text&srccharset=utf8&customerid=00000102&cache=0&sndpitch=100&sndspeed=100&sndtype=1&sndquality=4&sndgender=W&simpleparse=1
    Unfortunately, you can't download the audio file currently, but still you can record audio in other means.
  3. badsushi
    Mar 26, 2011
    27
    Last time we did this work around we just recorded over the phone - Never thought the prompts were high quality anyway. PCM, 8kHz, 16bit, mono = not high quality
  4. eagle2
    Apr 27, 2011
    1,085
    11
    You must record prompts into or convert them to PCM, 16-bit, 8 kHz, mono to ensure compatibility with various phone systems.
    Regards
