Dial-By-Name Directory With Short Names
Discussion in '3CX Phone System - General' started by cogent, Jan 18, 2018.
  1. cogent
    Apr 7, 2010
    I see that there have been other posts where people have mentioned that there is an issue with the dial-by-name directory if a person only has a 2 letter last name. 3CX' instructions say to enter a 0 following the first 2 letters of their name, but this is not reasonable. People calling in will have no idea that they need to do this. There needs to be a solution for this, and so far I have not seen an adequate one. In our case, allowing us to switch the directory to first name would solve the problem.
    Thanks,
    Jason
    11,073
    323
  3. cogent
    Apr 7, 2010
    Hi Leejor,
    Thanks.. Yes, I did see that one and I guess it is the only option at this point. It will create many more cases where a caller will have to select from multiple options, but it should at least work better than now.
