Dial By Name - Extension Not Found
Discussion in '3CX Phone System - General' started by systemstech, Feb 27, 2018.
  1. systemstech
    Dec 1, 2009
    Is there any way to resolve or bypass the dial by name "extension not found" without having the user record their name? Was hoping there was an option to bypass the name recording feature by default so the dial by name would work anyway.
    Thx, J
  2. Marari
    Marari New Member
    Sep 16, 2007
    207
    47
    User has to at least initialize the voicemail. Recorded name is easiest.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,302
    530
