Dial by Name V9
Discussion in '3CX Phone System - General' started by mchristsen, Jul 29, 2010.
  1. mchristsen
    Mar 30, 2010
    26
    I have upgraded from Version 8 to Version 9.
    I like the improved prompt on the Dial By Name, much nicer.
    However, one Extension only has a 2 digit last name, Wu.
    I get two results:
    1. 3CX sits an waits for the third key to be pressed.
    2. Returns Extension not found.
    My first questions is, does less than 3 letters work for Dial By Name?
    Second, if it only works with 3 or more, how do i overcome this?
    Michael.
    10,586
    252
    Does pressing the octothorp (#) help?
  3. mchristsen
    Mar 30, 2010
    26
    I apologize for reviving this thread, but the problem still persists.
    When an extension only has a 2 letter last name, the Dial by name does not work. Pressing # or * just repeats the dial by name. Pressing 1 or 0 at the end (for a space or something like that) gives you extension not found.
    I am currently runnning Version 9 SP3.
    Any ideas?
    Michael.
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Hi, 2 things if you read the manual Page 49 - you will see step by step how Call By Name works.
    Call By name only works when you dial the first 3 letters of the last name.
    Also when you call the IVR followed by the number to use call by name - IVR will prompty you to Select the FIRST 3 Letters of the last name.
    We cant match all combination because there are alot.
    Call by name works as described above.
    Thanks and Regards
  5. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    Unfortunately we cannot change this functionality to work with the 2 first letters of the last name as it would create more trouble than fix.
    Maybe you can rename Wu, to Woo or Wuu?
