Dial By Name
Discussion in '3CX Phone System - General' started by stevodevo, Sep 21, 2010.
  1. stevodevo
    Aug 17, 2010
    18
    I'm a new 3CX administrator (inherited system) and want to know if it's possible to have a 'dial by name' function in the system? So when a caller reaches the Auto Attendant, they would press x and then be allowed to type in the person's name on the keypad and the system would tell them (and forward them) to the extension.
    Is this possible?
    Steve
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,504
    100
    You can simply call a Digital Receptionist and dial the number of the person you want to call in the main menu.
    There is no need to even press anything.
  3. stevodevo
    Aug 17, 2010
    18
    Thanks Leonidas, but what if I don't know the extension of the person I am trying to call? I've used VoIP systems in the past where you could enter a name (rather than a number) and have that do a lookup against the company directory in the phone system.
    Is that possible?
  4. LeonidasG
    Nov 19, 2008
    1,504
    100
    Ah sorry i thought you meant something else from your post.
    You can also do what you're saying yes, if you know the name of the person you want to call, you can try entering the 3 first letters of their last name in the DR if you have the "Dial by name" option somewhere in the DR.
  5. stevodevo
    Aug 17, 2010
    18
    Okay I found the Dial by Name option in the Digital Receptionist setup. However, when I dial the first 3 digits of the person's last name, it says "extension not found". I'm dialing the last name exactly as it is set up in the Extension list. Is there something I'm missing in the set up?
  6. LeonidasG
    Nov 19, 2008
    1,504
    100
    Ah i forgot to mention, you would have to go to each extension's voice mail, menu 9 > 5 and record a new Self ID message to be their name.
    After that you should be able to call people with this feature.
  7. LeonidasG
    Nov 19, 2008
    1,504
    100
    So:
    1) Set up a Digital Receptionist with the Dial by Name option in it.
    2) Put a name and surname in each extension's settings.
    3) Go to each extension's voice mail option 9 and 5 and record their full name as the self identification message.
    You can now make call by name calls to those extensions via the DR.
