Dial By name
Discussion in '3CX Phone System - General' started by ardentsupport, Jul 19, 2013.
  1. ardentsupport
    Jul 19, 2013
    We have the dial by name enabled via the DR. When you hit 8 to dial by name it doesn't always prompt you to enter the first 3 letters of the last name. Half the time it just forwards to the operator. I have tried it numerous times and it is very random.
    any ideas?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    This is usually associated to the DTMF tones not being understood correctly by the system. This, of course, assumes that the input at the phone does indeed correspond to a valid name. You did not indicate if the issue is observed using a particular type of phone so -
    Use a landline analog phone and test, this should be the baseline and all should work well
    Use a cell/mobile and test. All should work well, but if not then see if the settings of the cell allow for a timing setting of the DTMF tones (some do and perhaps set too short)
    Use a IP-Phone and test, if one works they should all work provided that they are all set to use the same style of DTMF generation and duration (look in the phone using its web interface and you will see settings)
  3. ardentsupport
    Jul 19, 2013
    All the attempts where made from the same cell phone.
    thanks,
    Dave
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    When you dial by name you have to be sure that the users record both their actual greeting as welll as their name other wise thosee users will not be found.
  5. lneblett
    Sep 7, 2010
    2,088
    65
    Then, as suggested, look for the setting on your mobile to adjust dtmf. To confirm, try from a landline analog phone.
