Dial By Name
Discussion in '3CX Phone System - General' started by Brett Coleman, Aug 15, 2017.
  1. Brett Coleman
    Jun 20, 2017
    27
    Is there a way to determine which extensions are NOT enabled for dial by name?
    teldata1 likes this.
  2. neville
    neville New Member
    Apr 23, 2012
    202
    33
    If you are on Linux, do the following:
    Log into the server using WinSCP
    At the top right, click Find Files
    In the File mask: enter self_id_prompt.wav
    In the Search in: enter /var/lib/3cxpbx/Instance1/Data/Ivr/Voicemail/Data
    Click Start
    You will see which extension has the self_id_prompt.wav file
    This works for me.
