Dial code for transfer
Discussion in '3CX Phone System - General' started by Rob24h, Apr 12, 2018.
  1. Rob24h
    Mar 20, 2017
    69
    6
    I have a phone that has no built-in transfer button and I want to transfer an incoming call to a colleague. What dialcode can I use to transfer the caller?
    I am on 3CX v15.5 SP3
  2. StefanW
    Jun 2, 2009
    1,215
    87
    there is no option. You can use the 3CX WebClient to do this, but on the device it self we do not support this.
    We only support this on a service called MTA (mobile transfer agent) when you are getting calls in a call flow of ring my mobile simultaneous. But a normal internal extension, no do...
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    722
    123
    You could create a Call Flow Designer (CFD) application to do this provided you can put the caller on hold and make a second call. Dialing the CFD extension would prompt you for the extension where the call should be transferred, then the CFD would transfer the call on hold to the desired extension. I've not tested this, but I believe it is possible.
  4. Marari
    Marari New Member
    Sep 16, 2007
    121
    21
    As an option. you could always use call parking (*0x) and let the callee know to pickup the parked call (*1x)...
  5. leejor
    10,737
    281
    What type (make/model) set is this? Someone else may have had an experience with it, in the past.
