Dial Codes - Extension Not Found
Discussion in '3CX Phone System - General' started by Johnathan Penberrthy, Feb 6, 2017.
  1. Johnathan Penberrthy
    Feb 6, 2017
    10
    We are using Grandstream GXV3275 & GXP2200 phones. Which of course is not a supported provisioning phone. Though extensions are working using the SIP protocol.
    When using the Dial Codes (like intercom/paging), we get a "Extension Not Found" Voice prompt. All other dial codes are not working as well. Intercom/Paging was working when using asterisk.
    Any suggestions?
    11,291
    361
    What digits are you sending to the PBX? Are these the correct dial codes? Is this confirmed in the 3CX logs?
  3. Johnathan Penberrthy
    Feb 6, 2017
    10
    I have confirmed the dial codes in the settings.
    Codes like paging/intercom as *99(EXT) are being sent, and even dial extension VM as *(EXT).
    All being seen in the logs as answered for a couple seconds or not answered.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Navigate to settings / Dial tone settings and verify that the Dial codes match the ones you are dialling
  5. Johnathan Penberrthy
    Feb 6, 2017
    10
    As with my prior post, I have confirmed the dial codes.
  6. leejor
    11,291
    361
    So, if I understand correctly, even dialling the voicemail system number reaches a recording saying that it is not a valid extension? If hhat is the case, then compare (in the logs) dialling the same digits from a non-Grandstream set and one having the issue. Couls it be an internal dialplan that is modifying the digits sent to the PBX?
  7. Johnathan Penberrthy
    Feb 6, 2017
    10
    No the voicemail extension of 999 works. Just any code in the "Dial Code Settings" page does not work. The voicemail extension setting is in the Voicemail page under settings.
  8. leejor
    11,291
    361
    So anything with a "star" code then? If that is the case, then perhaps the set is just not sending the star (just the digits), for some reason. Again, perhaps, some internal, set, dial plan?
  9. Johnathan Penberrthy
    Feb 6, 2017
    10
    This is the dial plan on the phone: { x+ | \+x+ | *x+ | *xx*x+ }
  10. leejor
    11,291
    361
    Haven't used Grandstream dialplans previously, but that would appear to be the default plan, which should work.
    To invoke a feature, are you hitting a key, or actually dialling a star code? If you dial a star code, what digits does the 3CX log show that it received? Just the digits minus the *? If you are simply pressing a feature button, then perhaps that/those buttons are simply not programmed to send the correct code for the 3CX PBX. Different PBX's can use different codes and being a "non supported set" may mean that "configuration" is required to make the keys compatible with what 3CX expects to see when using a feature.
  11. Johnathan Penberrthy
    Feb 6, 2017
    10
    Nope, the person dials *80206 to invoke the intercom feature (which worked on PAIF asterisk). 3CX does show the call coming in as *80206, or any other dial code.
  12. leejor
    11,291
    361
  13. Johnathan Penberrthy
    Feb 6, 2017
    10
    Even the *9(EXT) setting does not work as well. No star code works.
  14. leejor
    11,291
    361
    Could this be a DTMF Method issue?
  15. Johnathan Penberrthy
    Feb 6, 2017
    10
    Even if this worked just fine on the old asterisk system. Also all phones are local to the phone server.
  16. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    {x+ | \S\Px | \+x+|*x+|*xx*x+} is the string for Grandstream that I am using - atleast on newer firmwares.
    Dial codes working without issue for me. (ie: *9200 to server room)
    I see mention of
    *<ext> - what should this do?
    *99<ext> - intercom (default is *9<ext>
    Do those phones have their own packet capture ability? If not - then setup a port mirror on your switch and run Wireshark on a laptop... Did you reset the phones to factory before provisioning for 3cx?
