dial from IE
Discussion in 'Windows' started by jeremyn, Mar 26, 2008.
  1. jeremyn
    Mar 25, 2008
    42
    Hi all,
    can someone please direct me to where I can get information about how it is possible to dial from a browser using 3cx
    thanks in advance
    Jeremy
  2. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    You can find it in the documentation, you can create an url with the number of the phone, voicemail pin number and the number you want to dial and 3cx will initiate the call.
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i'm afraid that this is a feature request. i was trying but you need something like an plugin... i will like it. if a take a look around on another PBX is a normal feature.
  4. jeremyn
    Mar 25, 2008
    42
    do you know the names of any plugins ?
  5. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    NO. Maybe the 3CX staff.......... Help. It's a daily question from our customers.
  6. bartus
    Apr 1, 2008
    I think the solution for this is the make_call script in html
    See http://www.3cx.com/support/http-post.html
    I don't know however if this is also working in the free version.
    I would like to pay for it if I would know how this will work
  7. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    what i ment is somethings like the plug in of skype. the number on the contact list on a web site have to be insert and with rght click call it.
  8. andrej_ka
    Apr 11, 2008
    I'm having a similar problem. We are using a CRM with 'callto://' and 'sip://' URIs for phone numbers. Right now I'm testing the 3CX softphone, hovever I cannot figure out, how to make it dial a number after a suser has clicked on such a link.
    Is there a way to make the softphone react on such links? 3CX staff?
    Or mayber there is a commandline syntax like 'C:\Program Files\....\3CXVoIPClient.exe -makecall numbernumber'?
  9. bartus
    Apr 1, 2008
    Hi Andrej,
    It looks like it that the built in feature for this "make_call.php" does not work. 3CX staff is not answering questions related to this subject.
    Bartus
  10. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi all
    i think this option is very usefull
    regards
  11. jeremyn
    Mar 25, 2008
    42
    where can i find the version 6 http api ?
