Dial or receive call on windows but speak using IP Phone
Discussion in '3CX Phone System - General' started by Raman Kalia, Nov 23, 2017.
  1. Raman Kalia
    Jun 7, 2017
    14
    Can a user dial a call using windows soft client but rather speak using IP phone. Many users want to use headsets of IP phone.
    Regards,
    Raman Kalia
    10,757
    286
    It can depend on the sets you are using. You want to use CTI mode. Do a search for that.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
  4. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Raman Kalia
    As already been said here, CTI is what you need. Both the windows client and the web client support this.
    Basically you will need to provision the windows client and ip phone with the same extension and switch to CTI Mode on the client. As for the web client, you'll need to login with the extension provisioned on ip phone
