Dial Plan - Outbound calls to 2 gateways
Discussion in '3CX Phone System - General' started by Serey, May 5, 2007.
  1. Serey
    May 5, 2007
    Hi all,
    I have configured one analog-PSTN-Voip Gateway and one VoIP provider. I would like that :
    - By default all outbound calls go trough the analog-PSTN Gateway
    - If the PSTN line is busy, a second outbound call goes trough the VoIP gateway.
    Is it possible to change the dial plan behavior when the IP PBX detects a busy line ?
    Thanks,
    Fabrice
  2. Anonymous
    Anonymous Guest
    To answer this question you have to understand what a dial plan does, it is build up out of possible 5 :
    Endpoint addressing
    Path selection
    Calling privileges
    Digit manipulation
    Call coverage
    These components are addressed when the caller dials the digits.
    What you want is call fail over, i am not aware that 3cx deals with this. It uses the gateway it is told to use based upon the dailout rule.
    I see a feature request comming up here and that is:
    use the next available gateway when dialing out (or incomming) should be configurable.
    Back to your question.
    The closes you can get to that now is to have a dial out rule per gateway, so that when the caller gets an engage signal they can use the other gateway by using a different prefix.
    At this point in time I do not believe that this is done by 3cx, the SPA3102 has a fail over feature that can be used but that is on ata level and outside the control of 3cx.
