dial plan?
Discussion in '3CX Phone System - General' started by aits, Oct 12, 2009.
  1. aits
    Oct 6, 2009
    12
    Why does this not work on a SPA-942/922?
    (P9 |*xxS0|[x*].)
    P9 tells my phone to wait 9 seconds to enter a key, but he still hooks up after the default 5 secs.
    when I use (p9 |<0,:0>x.<:mad:wg0>|[1-9]xS0) it works but the dial plan is not ok here for what I need to do...
    I need a dial plan that says:
    - wait till 9 secs. for a key
    - enable *xx for dial codes (*60, *61, *0, *1, *20*)
    - when a 0 is pushed give an external line tone (,) and proceed with all next numbers for this external line
    - internal lines are two digits (10,11,12,13,...)
    thanks
    11,105
    329
    If you want a Linksys device to wait (not give you fast busy) if you are a slow dialer, then you should be changing the Interdigit Short Timer in the Regional tab to 9 or 10 seconds.
    You may want to have a look at these sites, they give some examples: http://www.cisco.com/en/US/products/ps10030/products_qanda_item09186a0080a36623.shtml and ... http://www.scribd.com/doc/238209/LinksysSipura-Dial-Plan-tutorial
  3. aits
    Oct 6, 2009
    12
    The problem is not the time between numbers but before any number is typed...so not the interdigit parameter is what I need, the P parameter shoul do the trick but not always.
  4. aits
    Oct 6, 2009
    12
    problem solved, time adjustment in Regional - Interdigit Short Timer.
    So indeed no need to use dial plan for this.
    Thanks guys
