Dial plan?
Discussion in '3CX Phone System - General' started by monster666, Mar 22, 2010.
  1. monster666
    Mar 22, 2010
    We uses 3cx client to dial from a webbased sell system, the problem is that we have to dial 0 before to acess outside line.
    Is it posible to insert somehow that it always dials a 0 (zero) before the nr in the webbased sell system?
    Regards
    Marcus
    10,368
    228
    You are using the 3CX softphone? If so, I know of no way to prepend digits automatically to a dialled number. Some ATA's can be set to do something like that using the internal dialplans.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    if you have set your "web based sell system" to dial using the HTTP api you have to set the String to add a leading 0 before the dialing number.
