Dial tone provisioning help needed
Discussion in '3CX Phone System - General' started by spuddie, Sep 4, 2014.
  1. spuddie
    Sep 3, 2014
    10
    Hi everyone
    I'm looking for a little guidance, I've been putting together an xml file with all the provisioning info we need for the Cisco SPA02G, the very last one I'm stuck on and can't find where to add 4 dial tone options which go under the Regional Tab then Call Progress Tones.
    I've tried to guess adding the below in but no luck:
    <Dial_Tone="Regional/Call Progress Tones">420@-19,520@-19;10(*/0/1+2)</Dial_Tone>
    <Outside_Dial_Tone="Regional/Call Progress Tones">350@-19,440@-19;10(*/0/1+2)</Outside_Dial_Tone>
    <Busy_Tone="Regional/Call Progress Tones">400@-10; 10(0.375/0.375/1)</Busy_Tone>
    <Ringback_Tone="Regional/Call Progress Tones">440@-19,480@-19;*(2/4/1+2)</Ringback_Tone>
    Is anyone able to help?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    Hi there,
    It might be worth having a look the Administration Manual for the Cisco phone which could contain this information, however I feel that this question would be more easily answered on the Cisco forum.
