Dialed Number for Inbound Calls
Discussion in '3CX Phone System - General' started by JHedges, Aug 8, 2014.
  1. JHedges
    Jun 10, 2014
    Hi hoping someone can help me figure this out -- I sure haven't yet.
    We have about 50 toll free number placeholders registered in our 3CX system. Each as their own inbound rule forwarding to an IVR. I'm trying to get the system to tell me what number was dialed on the inbound calls so we can manage a proper response.
    The built-in emails about a missed call do not have the number, they only show the IVR extension / name. So, I tried to make my own DLL from the Call Control API. Unfortunately the dialed number is not exposed :(. I'm able to pull all of the ActiveConnection properties, and there IS a DialedNumber property (but it is always blank), however none show the proper dialed number that the person / robot called in as. Quite frustrating.
    The verbose Server Activity Logs do have the number in the SIP header... so I know 3CX keeps track of it somewhere!
    Has anyone come up with a solution for this?
    Code:
                try
                    Tenant[] tenantArr = PhoneSystem.Root.GetTenants();
                    DN[] dnArr = tenantArr[0].GetDN();
                    File.AppendAllText(path, "Successfully tied into PhoneSystem. \n");
                    foreach (DN dn in dnArr)
                        ActiveConnection[] connections = dn.GetActiveConnections();
                        foreach (ActiveConnection activeConnection in connections)
                            File.AppendAllText(path, String.Format("DialedNumber: {0} \n", activeConnection.DialedNumber)); //always empty
                            File.AppendAllText(path, String.Format("CallID: {0} \n", activeConnection.CallID));
                            File.AppendAllText(path, String.Format("InternalParty: {0} \n", activeConnection.InternalParty)); //just gives 861 the IVR extension #
                            File.AppendAllText(path, String.Format("Referred By: {0} \n", activeConnection.ReferredBy));
                            File.AppendAllText(path, String.Format("ExternalParty: {0} \n", activeConnection.ExternalParty));
                            File.AppendAllText(path, String.Format("CallConnectionID: {0} \n", activeConnection.CallConnectionID));
                            if (activeConnection.ExternalParty == callerID)
                                File.AppendAllText(path, String.Format("Match found for {0} \n", callerID));
                                return activeConnection.DialedNumber;
                    File.AppendAllText(path, String.Format("Match not for {0} \n", callerID));
                    return "Not Found.";
  2. comnia
    Dec 13, 2013
    15
    Hey There,
    we are using version 12 and are facing the same problem (DialedNumber always blank).
    Anyone using older versions where this works?
    Thanks from Munich!
  3. leejor
    11,086
    325
    Have you set 3CX to prepend, or append, the DID name,which could be a number, if you have a unique route for every DID.
    http://www.3cx.com/docs/trunk-management/ See Adding DIDs, point 2
