Dialing a bridged extension from the IVR
Discussion in '3CX Phone System - General' started by xirgo, Jan 17, 2018.
  1. xirgo
    Nov 9, 2015
    22
    We've recently enabled a bridge between two 3CX instances running the latest V15.5
    One thing that we noticed right away is that through the IVR it's not possible to dial an extension on a remote bridge instance.
    The extensions on the bridged 3CX is in the 100 range while the Master 3CX they are in the 200 range.
    These extensions can be reached internally when dialing from one extension to another.
    Ive found this article of a user who found a sort of work around however It appears to be dated and opens a security hole. (see https://www.3cx.com/community/threads/dialing-a-bridged-extension-from-the-ivr.44914/)
    I'd like to know if there is a better method of accomplishing this with the latest V15.5 or if there is a more secure workaround.
    Thanks!
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    As far as I know this is the only way to make call through IVR to the outside number / extension
  3. leejor
    10,758
    286
