Dialing in 3CX
Discussion in '3CX Phone System - General' started by jsadan, May 7, 2010.
  1. jsadan
    May 3, 2010
    91
    Is there a way when dialing a 7 digit number to automatically dial our local area code?
  2. Destonomos
    Apr 30, 2010
    18
    you can setup rules to prepend digits, yes
  3. jsadan
    May 3, 2010
    91
    Alright currently my settings are like so
    Rule Name: Area Code
    Calls to numbers starting with (Prefix): (Blank)
    Calls from extensions: 120-140
    Calls to numbers with a length of: 7
    Route: Teliax | Strip: 0 | Prepend: 805 <-(Area Code)
    Is this correct?
  4. jsadan
    May 3, 2010
    91
    Found out my issue, had two outbound rules and my Area Code rule was on the bottom of the list. Wasnt aware order mattered but put it on top and it worked fine. Ended up combining both rules into one. Appreciate the help Destonomos!
