Dialing out problems.
Discussion in '3CX Phone System - General' started by abelaguilar, Jan 18, 2008.
  1. abelaguilar
    Nov 4, 2007
    94
    Not sure if this is a polycom 501 settings issue. It seems to happen mainly when dialing numbers with area codes. AFter several tries it seems to then send the call out and works fine.
    I'v read somewhere that if the phone dials the numbers to fast, the server may not pick up all the digits and there is a way to slow this down.
    Has anyone had this problem?
  2. abelaguilar
    Nov 4, 2007
    94
    Here is the log :
    09:18:58.453 Call::Terminate [CM503008]: Call(13): Call is terminated
    09:18:38.156 CallLeg::eek:nConfirmed Session 151 of leg C:13.1 is confirmed
    09:18:38.015 CallCtrl::eek:nLegConnected [CM503007]: Call(13): Device joined: sip:10000@192.168.0.105:5060
    09:18:38.015 CallCtrl::eek:nLegConnected [CM503007]: Call(13): Device joined: sip:106@192.168.0.5:5060
    09:18:38.000 MediaServerReporting::SetRemoteParty [MS210007] C:13.1:Answer provided. Connection(by pass mode): 192.168.0.105:5220(5221)
    09:18:38.000 MediaServerReporting::SetRemoteParty [MS210001] C:13.2:Answer received. RTP connection: 192.168.0.105:5220(5221)
    09:18:38.000 CallLeg::setRemoteSdp Remote SDP is set for legC:13.2
    09:18:34.984 Line::printEndpointInfo [CM505002]: Gateway:[patton] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4118 4JS4JO EUI MxSF v3.2.8.45 00A0BA0350F7 R3.21 2007-05-14 H323 SIP FXS FXO] Transport: [sip:192.168.0.102:5060]
    09:18:34.984 CallCtrl::eek:nAnsweredCall [CM503002]: Call(13): Alerting sip:10000@192.168.0.105:5060
  3. abelaguilar
    Nov 4, 2007
    94
    Can someone tell me if getting rid of my polycom 501 and exchanging it for someting else would solve this problem. ?
    Thjanks
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please post the gateway debug log here as well. It should be help to solve your issue.
  5. abelaguilar
    Nov 4, 2007
    94
    Can you tell me how to get the gateway debug log?
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    telnet to your Patton gateway IP.
    1. type enable then enter
    2. type debug call-control then enter
  7. abelaguilar
    Nov 4, 2007
    94
    Great thanks allot!!!
  8. abelaguilar
    Nov 4, 2007
    94
    is there a default login username and password for the patton smartnode series when telneting ? I don't know it.
  9. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    By default, the user is administrator and password is blank.
  10. abelaguilar
    Nov 4, 2007
    94
    ok here is the log.
    again, randomly some call go through and others don'e. I gget the operator error stating please check your number and try again.
    login: administrator
    password:
    SN4118/4JS4JO/EUI>enable
    SN4118/4JS4JO/EUI#debug call-control
    SN4118/4JS4JO/EUI#debug gateway sip transport detail 5
    SN4118/4JS4JO/EUI#debug gateway sip error detail 5
    SN4118/4JS4JO/EUI#debug ccfxo
    SN4118/4JS4JO/EUI#debug fxo
    SN4118/4JS4JO/EUI#03:13:28 FXO > [0 0] Line up.
    03:13:28 FXO > FxoPortSM: state=wait-for-up, event=link-up
    03:13:28 FXO > FxoPortSM: notifying link-up
    03:13:28 FXO > [0 0] Set state to 'OnHook'
    03:13:28 FXO > FxoPortSM: new state=on-hook
    03:13:28 FXO > FxoPortSM: notifying caller-id-enable
    03:13:28 CFXO > [EP fxoif0] State DISABLED, event PORT_ENABLED
    03:13:28 CFXO > [EP fxoif0] Change state to IDLE.
    03:13:28 CFXO > [EP fxoif0] Change datapath direction to receive-only.
    03:13:28 CFXO > [EP fxoif0] Change datapath direction to inactive.
    03:13:46 SIP_TR> [GW] < Stack: from 192.168.0.102:5060
    INVITE sip:18007336628@192.168.0.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK-d87543-10126a458e70e254-1--d8 7543-;rport
    Max-Forwards: 70
    Contact: <sip:10000@192.168.0.102:5060>
    To: <sip:18007336628@192.168.0.105:5060>
    From: "106"<sip:10000@192.168.0.102:5060>;tag=b24e1219
    Call-ID: MzllYTliMTE2MTk5ZjQ2NGYzYjczMTQ3OTFmMjQ4ZmI.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, IN FO
    Content-Type: application/sdp
    User-Agent: 3CXPhoneSystem 5.0.3790.0
    Content-Length: 257
    v=0
    o=3cxPS 122188464128 445015654401 IN IP4 192.168.0.102
    s=3cxPS Audio call
    c=IN IP4 192.168.0.5
    t=0 0
    m=audio 2224 RTP/AVP 0 8 18 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:18 G729/8000
    a=rtpmap:101 telephone-event/8000
    a=sendrecv
    03:13:46 SIP_TR> [GW] > Stack: to 192.168.0.102:5060
    SIP/2.0 100 Trying
    CSeq: 1 INVITE
    From: "106" <sip:10000@192.168.0.102:5060>;tag=b24e1219
    To: <sip:18007336628@192.168.0.105:5060>;tag=78d2ac7c41b127a
    Content-Length: 0
    User-Agent: Patton SN4118 4JS4JO EUI MxSF v3.2.8.45 00A0BA0350F7 R3.21 2007-05-1 4 H323 SIP FXS FXO
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Network -> sipgw0
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: E164-Number -> 10000
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: URI -> sip: 10000@192.168.0.102:5060
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Type-Of-Num ber -> Unknown
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Numbering-P lan -> Unknown
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Presentatio n-Indicator -> Presentation allowed
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Name -> 106
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Screening-I ndicator -> User provided, not screened
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Supports Ov erlap-Sending -> true
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Supported C odecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Unique Iden tifier -> MzllYTliMTE2MTk5ZjQ2NGYzYjczMTQ3OTFmMjQ4ZmI.
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: IP-Address -> 192.168.0.102
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Call-Leg-ID -> 0x00ca6030
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: State -> CO NNECTED
    03:13:46 CC > [Call 00ca66c8] Set call property: Context -> 0x00000022
    03:13:46 CC > [Call 00ca66c8] Set call property: Information-Transfer-Capabi lity -> 3.1kHz Audio
    03:13:46 CC > [Call 00ca66c8] Set call property: Hops -> 0x00000010
    03:13:46 CC > [EP sipif0-00cb4c88/active] Dial to provider router (sipif0-pr ecall-service) using call 00ca66c8
    03:13:46 CC > [EP router-00ca65c8/incoming] Accept call 00ca66c8
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: E164-Numb er -> 18007336628
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: Type-Of-N umber -> Unknown
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: Numbering -Plan -> Unknown
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: Name ->
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: URI -> si p:18007336628@192.168.0.105:5060
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: Network - > router
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: Call-Leg- ID -> 0x00caa560
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: State -> TRYING
    03:13:46 CC > [EP router-00ca65c8] Start route-lookup
    03:13:46 CC > [EP router-00ca65c8] Route found; immediately place call
    03:13:46 CC > [EP router-00ca65c8] Route to provider 'fxohuntgroup'
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: E164-Numb er -> 10000
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: URI -> si p:10000@192.168.0.102:5060
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Type-Of-N umber -> Unknown
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Numbering -Plan -> Unknown
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Presentat ion-Indicator -> Presentation allowed
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Name -> 1 06
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Screening -Indicator -> User provided, not screened
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Supports Overlap-Sending -> true
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Unique Id entifier -> MzllYTliMTE2MTk5ZjQ2NGYzYjczMTQ3OTFmMjQ4ZmI.
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: IP-Addres s -> 192.168.0.102
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Network - > router
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Call-Leg- ID -> 0x00cac670
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: State -> CONNECTED
    03:13:46 CC > [Call 00cac418] Set call property: Context -> 0x00000022
    03:13:46 CC > [Call 00cac418] Set call property: Information-Transfer-Capabi lity -> 3.1kHz Audio
    03:13:46 CC > [Call 00cac418] Set call property: Hops -> 0x0000000f
    03:13:46 CC > [EP router-00ca65c8/outgoing] Dial to provider fxohuntgroup () using call 00cac418
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Accept call 00cac418
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: E16 4-Number -> 18007336628
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Typ e-Of-Number -> Unknown
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Num bering-Plan -> Unknown
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Nam e ->
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: URI -> sip:18007336628@192.168.0.105:5060
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Net work -> fxohuntgroup
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Cal l-Leg-ID -> 0x00cad1a0
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Sta te -> TRYING
    03:13:46 CC > [EP fxohuntgroup-00cace00] Hunt to fxoif0 ()
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: E16 4-Number -> 10000
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: URI -> sip:10000@192.168.0.102:5060
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Typ e-Of-Number -> Unknown
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Num bering-Plan -> Unknown
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Pre sentation-Indicator -> Presentation allowed
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Nam e -> 106
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Scr eening-Indicator -> User provided, not screened
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Sup ports Overlap-Sending -> true
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Sup ported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Uni que Identifier -> MzllYTliMTE2MTk5ZjQ2NGYzYjczMTQ3OTFmMjQ4ZmI.
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: IP- Address -> 192.168.0.102
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Net work -> fxohuntgroup
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Cal l-Leg-ID -> 0x00979398
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Sta te -> CONNECTED
    03:13:46 CC > [Call 009782c0] Set call property: Context -> 0x00000022
    03:13:46 CC > [Call 009782c0] Set call property: Information-Transfer-Capabi lity -> 3.1kHz Audio
    03:13:46 CC > [Call 009782c0] Set call property: Hops -> 0x0000000e
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Dial to provider fxoif0 () using call 009782c0
    03:13:46 CFXO > [EP fxoif0] State IDLE, event OFFER
    03:13:46 CC > [EP fxoif0/active] Accept call 009782c0
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: E164-Number -> 18007 336628
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: Type-Of-Number -> Un known
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: Numbering-Plan -> Un known
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: Name ->
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: URI -> sip:180073366 28@192.168.0.105:5060
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: Network -> fxoif0
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: Call-Leg-ID -> 0x009 7a5d8
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: State -> TRYING
    03:13:46 FXO > FxoPortSM: state=on-hook, event=off-hook
    03:13:46 FXO > FxoPortSM: notifying off-hook
    03:13:46 FXO > [0 0] Set state to 'OffHook'
    03:13:46 FXO > FxoPortSM: new state=off-hook
    03:13:46 FXO > FxoPortSM: notifying caller-id-disable
    03:13:46 CFXO > [EP fxoif0] Change state to WAIT BEFORE DIALING.
    03:13:46 CC > [EP fxoif0/active] Set call-leg property: Provides Data -> tru e
    03:13:46 CC > [Call 00ca66c8] Set call property: Hops -> 0x0000000f
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Net work -> router
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Cal l-Leg-ID -> 0x00cac670
    03:13:46 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Pro vides Data -> true
    03:13:46 CFXO > [EP fxoif0] State WAIT BEFORE DIALING, event PEER_CONNECTED
    03:13:46 CC > [EP router-00ca65c8/incoming] Set call-leg property: Provides Data -> true
    03:13:46 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Provides Da ta -> true
    SIP/2.0 183 Session Progress
    CSeq: 1 INVITE
    Content-Length: 205
    Contact: sip:18007336628@192.168.0.105:5060
    v=0
    o=MxSIP 0 213 IN IP4 192.168.0.105
    s=SIP Call
    c=IN IP4 192.168.0.105
    t=0 0
    m=audio 5272 RTP/AVP 0 8 101
    a=sendrecv
    03:13:46 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Provides Data -> true
    03:13:46 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Pro vides Data -> true
    03:13:46 CFXO > [EP fxoif0] Change datapath direction to send/receive.
    03:13:47 CFXO > [EP fxoif0] State WAIT BEFORE DIALING, event TIMEOUT
    03:13:47 CFXO > [EP fxoif0] Change state to DIALING.
    03:13:47 CFXO > [EP fxoif0] Dialing to terminal: 18007336628
    03:13:50 CFXO > [EP fxoif0] State DIALING, event TIMEOUT
    03:13:50 CFXO > [EP fxoif0] Change state to ACTIVE.
    03:13:50 CC > [EP fxoif0/active] Set call-leg property: State -> CONNECTED
    03:13:50 CC > [EP fxohuntgroup-00cace00] Hunting definitely succeeded
    03:13:50 CC > [EP fxohuntgroup-00cace00/incoming] Transfer call 009782c0 to 00cac418 ==> conference
    03:13:50 CC > [EP fxohuntgroup-00cace00/incoming] Drop call 00cac418
    03:13:50 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Pro vides Data -> false
    03:13:50 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Cau se -> Normal call clearing
    03:13:50 CC > [EP fxohuntgroup-00cace00/incoming] Set call-leg property: Sta te -> RELEASED
    03:13:50 CC > [EP fxohuntgroup-00cace00/outgoing] Drop call 009782c0
    03:13:50 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Pro vides Data -> false
    03:13:50 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Cau se -> Normal call clearing
    03:13:50 CC > [EP fxohuntgroup-00cace00/outgoing] Set call-leg property: Sta te -> RELEASED
    03:13:50 CC > [EP router-00ca65c8] Routing succeeded
    03:13:50 CC > [EP router-00ca65c8/incoming] Transfer call 00cac418 to 00ca66 c8 ==> conference
    03:13:50 CC > [EP router-00ca65c8/incoming] Drop call 00ca66c8
    03:13:50 CC > [EP router-00ca65c8/incoming] Set call-leg property: Provides Data -> false
    03:13:50 CC > [EP router-00ca65c8/incoming] Set call-leg property: Cause -> Normal call clearing
    03:13:50 CC > [EP router-00ca65c8/incoming] Set call-leg property: State -> RELEASED
    03:13:50 CC > [EP router-00ca65c8/outgoing] Drop call 00cac418
    03:13:50 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Provides Data -> false
    03:13:50 CC > [EP router-00ca65c8/outgoing] Set call-leg property: Cause -> Normal call clearing
    03:13:50 CC > [EP router-00ca65c8/outgoing] Set call-leg property: State -> RELEASED
    03:13:50 SIP_TR> [GW] > Stack: to 192.168.0.102:5060
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Content-Length: 205
    Supported: replaces
    v=0
    s=SIP Call
    t=0 0
    a=sendrecv
    03:13:50 SIP_TR> [GW] < Stack: from 192.168.0.102:5060
    ACK sip:18007336628@192.168.0.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK-d87543-ad5f4f0a1b2c8408-1--d8 7543-;rport
    Max-Forwards: 70
    CSeq: 1 ACK
    Content-Length: 0
    03:14:01 SIP_TR> [GW] < Stack: from 192.168.0.102:5060
    BYE sip:18007336628@192.168.0.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK-d87543-7178cb7d4a5f3125-1--d8 7543-;rport
    Max-Forwards: 70
    CSeq: 2 BYE
    Content-Length: 0
    03:14:01 SIP_TR> [GW] > Stack: to 192.168.0.102:5060
    SIP/2.0 200 OK
    CSeq: 2 BYE
    Content-Length: 0
    Supported: replaces
    03:14:01 CC > [EP sipif0-00cb4c88/active] Drop call 00ca66c8
    03:14:01 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Provides Da ta -> false
    03:14:01 CC > [EP sipif0-00cb4c88/active] Set call-leg property: Cause -> No rmal call clearing
    03:14:01 CC > [EP sipif0-00cb4c88/active] Set call-leg property: State -> RE LEASED
    03:14:01 CFXO > [EP fxoif0] State ACTIVE, event PEER_RELEASED
    03:14:01 FXO > FxoPortSM: state=off-hook, event=on-hook
    03:14:01 FXO > FxoPortSM: notifying on-hook
    03:14:01 FXO > [0 0] Set state to 'OnHook'
    03:14:01 FXO > FxoPortSM: new state=on-hook
    03:14:01 FXO > FxoPortSM: notifying caller-id-enable
    03:14:01 CFXO > [EP fxoif0] Change state to IDLE.
    03:14:01 CC > [EP fxoif0/active] Drop call 00ca66c8
    03:14:01 CC > [EP fxoif0/active] Set call-leg property: Provides Data -> fal se
    03:14:01 CC > [EP fxoif0/active] Set call-leg property: State -> RELEASED
    03:14:01 CFXO > [EP fxoif0] Change datapath direction to receive-only.
    03:14:01 CFXO > [EP fxoif0] Change datapath direction to inactive.
    SN4118/4JS4JO/EUI#clear
    SN4118/4JS4JO/EUI#03:15:39 SIP_TR> [GW] < Stack: from 192.168.0.102:5060
    INVITE sip:18003382000@192.168.0.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK-d87543-901e3a0bea3aad55-1--d87543-;rport
    Max-Forwards: 70
    To: <sip:18003382000@192.168.0.105:5060>
    From: "106"<sip:10000@192.168.0.102:5060>;tag=082c211d
    Call-ID: MDZiMWNkYzkyZTZmYmZkMDY1NmE2YTJjZTk1ZGFmM2Y.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Content-Length: 257
    v=0
    o=3cxPS 433305157632 223539625985 IN IP4 192.168.0.102
    s=3cxPS Audio call
    t=0 0
    m=audio 2226 RTP/AVP 0 8 18 101
    a=sendrecv
    03:15:39 SIP_TR> [GW] > Stack: to 192.168.0.102:5060
    SIP/2.0 100 Trying
    CSeq: 1 INVITE
    From: "106" <sip:10000@192.168.0.102:5060>;tag=082c211d
    To: <sip:18003382000@192.168.0.105:5060>;tag=45e3cbaabcfaf91
    Content-Length: 0
    User-Agent: Patton SN4118 4JS4JO EUI MxSF v3.2.8.45 00A0BA0350F7 R3.21 2007-05-14 H323 SIP FXS FXO
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Network -> sipgw0
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: E164-Number -> 10000
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: URI -> sip:10000@192.168.0.102:5060
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Type-Of-Number -> Unknown
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Numbering-Plan -> Unknown
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Presentation-Indicator -> Presentation allowed
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Name -> 106
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Screening-Indicator -> User provided, not screened
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Supports Overlap-Sending -> true
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Unique Identifier -> MDZiMWNkYzkyZTZmYmZkMDY1NmE2YTJjZTk1ZGFmM2Y.
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: IP-Address -> 192.168.0.102
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Call-Leg-ID -> 0x00974888
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: State -> CONNECTED
    03:15:39 CC > [Call 00ca9cc0] Set call property: Context -> 0x00000022
    03:15:39 CC > [Call 00ca9cc0] Set call property: Information-Transfer-Capability -> 3.1kHz Audio
    03:15:39 CC > [Call 00ca9cc0] Set call property: Hops -> 0x00000010
    03:15:39 CC > [EP sipif0-00c3ee90/active] Dial to provider router (sipif0-precall-service) using call 00ca9cc0
    03:15:39 CC > [EP router-00974f90/incoming] Accept call 00ca9cc0
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: E164-Number -> 18003382000
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: Type-Of-Number -> Unknown
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: Numbering-Plan -> Unknown
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: Name ->
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: URI -> sip:18003382000@192.168.0.105:5060
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: Network -> router
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: Call-Leg-ID -> 0x00974770
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: State -> TRYING
    03:15:39 CC > [EP router-00974f90] Start route-lookup
    03:15:39 CC > [EP router-00974f90] Route found; immediately place call
    03:15:39 CC > [EP router-00974f90] Route to provider 'fxohuntgroup'
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: E164-Number -> 10000
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: URI -> sip:10000@192.168.0.102:5060
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Type-Of-Number -> Unknown
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Numbering-Plan -> Unknown
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Presentation-Indicator -> Presentation allowed
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Name -> 106
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Screening-Indicator -> User provided, not screened
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Supports Overlap-Sending -> true
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Unique Identifier -> MDZiMWNkYzkyZTZmYmZkMDY1NmE2YTJjZTk1ZGFmM2Y.
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: IP-Address -> 192.168.0.102
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Network -> router
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Call-Leg-ID -> 0x00cac538
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: State -> CONNECTED
    03:15:39 CC > [Call 00cac2a0] Set call property: Context -> 0x00000022
    03:15:39 CC > [Call 00cac2a0] Set call property: Information-Transfer-Capability -> 3.1kHz Audio
    03:15:39 CC > [Call 00cac2a0] Set call property: Hops -> 0x0000000f
    03:15:39 CC > [EP router-00974f90/outgoing] Dial to provider fxohuntgroup () using call 00cac2a0
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Accept call 00cac2a0
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: E164-Number -> 18003382000
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Type-Of-Number -> Unknown
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Numbering-Plan -> Unknown
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Name ->
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: URI -> sip:18003382000@192.168.0.105:5060
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Network -> fxohuntgroup
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Call-Leg-ID -> 0x00975168
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: State -> TRYING
    03:15:39 CC > [EP fxohuntgroup-00cace28] Hunt to fxoif0 ()
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: E164-Number -> 10000
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: URI -> sip:10000@192.168.0.102:5060
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Type-Of-Number -> Unknown
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Numbering-Plan -> Unknown
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Presentation-Indicator -> Presentation allowed
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Name -> 106
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Screening-Indicator -> User provided, not screened
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Supports Overlap-Sending -> true
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Supported Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20]
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Unique Identifier -> MDZiMWNkYzkyZTZmYmZkMDY1NmE2YTJjZTk1ZGFmM2Y.
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: IP-Address -> 192.168.0.102
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Network -> fxohuntgroup
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Call-Leg-ID -> 0x00979478
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: State -> CONNECTED
    03:15:39 CC > [Call 00979360] Set call property: Context -> 0x00000022
    03:15:39 CC > [Call 00979360] Set call property: Information-Transfer-Capability -> 3.1kHz Audio
    03:15:39 CC > [Call 00979360] Set call property: Hops -> 0x0000000e
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Dial to provider fxoif0 () using call 00979360
    03:15:39 CFXO > [EP fxoif0] State IDLE, event OFFER
    03:15:39 CC > [EP fxoif0/active] Accept call 00979360
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: E164-Number -> 18003382000
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: Type-Of-Number -> Unknown
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: Numbering-Plan -> Unknown
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: Name ->
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: URI -> sip:18003382000@192.168.0.105:5060
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: Network -> fxoif0
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: Call-Leg-ID -> 0x0097a720
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: State -> TRYING
    03:15:39 FXO > FxoPortSM: state=on-hook, event=off-hook
    03:15:39 FXO > FxoPortSM: notifying off-hook
    03:15:39 FXO > [0 0] Set state to 'OffHook'
    03:15:39 FXO > FxoPortSM: new state=off-hook
    03:15:39 FXO > FxoPortSM: notifying caller-id-disable
    03:15:39 CFXO > [EP fxoif0] Change state to WAIT BEFORE DIALING.
    03:15:39 CC > [EP fxoif0/active] Set call-leg property: Provides Data -> true
    03:15:39 CC > [Call 00ca9cc0] Set call property: Hops -> 0x0000000f
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Network -> router
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Call-Leg-ID -> 0x00cac538
    03:15:39 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Provides Data -> true
    03:15:39 CFXO > [EP fxoif0] State WAIT BEFORE DIALING, event PEER_CONNECTED
    03:15:39 CC > [EP router-00974f90/incoming] Set call-leg property: Provides Data -> true
    03:15:39 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Provides Data -> true
    CSeq: 1 INVITE
    Content-Length: 205
    Contact: sip:18003382000@192.168.0.105:5060
    v=0
    o=MxSIP 0 214 IN IP4 192.168.0.105
    s=SIP Call
    t=0 0
    m=audio 5276 RTP/AVP 0 8 101
    a=sendrecv
    03:15:39 CC > [EP router-00974f90/outgoing] Set call-leg property: Provides Data -> true
    03:15:39 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Provides Data -> true
    03:15:39 CFXO > [EP fxoif0] Change datapath direction to send/receive.
    03:15:40 CFXO > [EP fxoif0] State WAIT BEFORE DIALING, event TIMEOUT
    03:15:40 CFXO > [EP fxoif0] Change state to DIALING.
    03:15:40 CFXO > [EP fxoif0] Dialing to terminal: 18003382000
    03:15:43 CFXO > [EP fxoif0] State DIALING, event TIMEOUT
    03:15:43 CFXO > [EP fxoif0] Change state to ACTIVE.
    03:15:43 CC > [EP fxoif0/active] Set call-leg property: State -> CONNECTED
    03:15:43 CC > [EP fxohuntgroup-00cace28] Hunting definitely succeeded
    03:15:43 CC > [EP fxohuntgroup-00cace28/incoming] Transfer call 00979360 to 00cac2a0 ==> conference
    03:15:43 CC > [EP fxohuntgroup-00cace28/incoming] Drop call 00cac2a0
    03:15:43 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Provides Data -> false
    03:15:43 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: Cause -> Normal call clearing
    03:15:43 CC > [EP fxohuntgroup-00cace28/incoming] Set call-leg property: State -> RELEASED
    03:15:43 CC > [EP fxohuntgroup-00cace28/outgoing] Drop call 00979360
    03:15:43 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Provides Data -> false
    03:15:43 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: Cause -> Normal call clearing
    03:15:43 CC > [EP fxohuntgroup-00cace28/outgoing] Set call-leg property: State -> RELEASED
    03:15:43 CC > [EP router-00974f90] Routing succeeded
    03:15:43 CC > [EP router-00974f90/incoming] Transfer call 00cac2a0 to 00ca9cc0 ==> conference
    03:15:43 CC > [EP router-00974f90/incoming] Drop call 00ca9cc0
    03:15:43 CC > [EP router-00974f90/incoming] Set call-leg property: Provides Data -> false
    03:15:43 CC > [EP router-00974f90/incoming] Set call-leg property: Cause -> Normal call clearing
    03:15:43 CC > [EP router-00974f90/incoming] Set call-leg property: State -> RELEASED
    03:15:43 CC > [EP router-00974f90/outgoing] Drop call 00cac2a0
    03:15:43 CC > [EP router-00974f90/outgoing] Set call-leg property: Provides Data -> false
    03:15:43 CC > [EP router-00974f90/outgoing] Set call-leg property: Cause -> Normal call clearing
    03:15:43 CC > [EP router-00974f90/outgoing] Set call-leg property: State -> RELEASED
    03:15:43 SIP_TR> [GW] > Stack: to 192.168.0.102:5060
    SIP/2.0 200 OK
    CSeq: 1 INVITE
    Content-Length: 205
    Supported: replaces
    v=0
    s=SIP Call
    t=0 0
    a=sendrecv
    03:15:43 SIP_TR> [GW] < Stack: from 192.168.0.102:5060
    ACK sip:18003382000@192.168.0.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK-d87543-033b951f344fca32-1--d87543-;rport
    Max-Forwards: 70
    CSeq: 1 ACK
    Content-Length: 0
    03:15:57 SIP_TR> [GW] < Stack: from 192.168.0.102:5060
    BYE sip:18003382000@192.168.0.105:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.102:5060;branch=z9hG4bK-d87543-1119313aee5b9a55-1--d87543-;rport
    Max-Forwards: 70
    CSeq: 2 BYE
    Content-Length: 0
    03:15:57 SIP_TR> [GW] > Stack: to 192.168.0.102:5060
    SIP/2.0 200 OK
    CSeq: 2 BYE
    Content-Length: 0
    Supported: replaces
    03:15:57 CC > [EP sipif0-00c3ee90/active] Drop call 00ca9cc0
    03:15:57 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Provides Data -> false
    03:15:57 CC > [EP sipif0-00c3ee90/active] Set call-leg property: Cause -> Normal call clearing
    03:15:57 CC > [EP sipif0-00c3ee90/active] Set call-leg property: State -> RELEASED
    03:15:57 CFXO > [EP fxoif0] State ACTIVE, event PEER_RELEASED
    03:15:57 FXO > FxoPortSM: state=off-hook, event=on-hook
    03:15:57 FXO > FxoPortSM: notifying on-hook
    03:15:57 FXO > [0 0] Set state to 'OnHook'
    03:15:57 FXO > FxoPortSM: new state=on-hook
    03:15:57 FXO > FxoPortSM: notifying caller-id-enable
    03:15:57 CFXO > [EP fxoif0] Change state to IDLE.
    03:15:57 CC > [EP fxoif0/active] Drop call 00ca9cc0
    03:15:57 CC > [EP fxoif0/active] Set call-leg property: Provides Data -> false
    03:15:57 CC > [EP fxoif0/active] Set call-leg property: State -> RELEASED
    03:15:57 CFXO > [EP fxoif0] Change datapath direction to receive-only.
    03:15:57 CFXO > [EP fxoif0] Change datapath direction to inactive.
  11. abelaguilar
    Nov 4, 2007
    94
    Hey yall
    in the interest of helping others. this problem was fixed by simply upgrading to the latest firmware. Looks like there was a bug where the fxo port was hanging and not letting some calls go out.
  12. mariamchik
    Apr 9, 2008
    tell me please!!!
    what version of firmware you upgrade for resilving problem?
