Dialing Pause in Outgoing Rule
Discussion in '3CX Phone System - General' started by alonchu, Feb 9, 2011.
  1. alonchu
    Jul 18, 2008
    21
    I am trying to setup an outgoing rule that uses a calling card we have for international calling.
    Does anybody know how to insert pauses in the outgoing rule?
    I want to prepend a number, with pauses prior the number dialed.
    Thanks,
    Alon
    11,133
    331
    You can't, with SIP, the digits are all sent at once (as a message). You could do it from a telephone set with built in speed call memory, but not as an outbound rule. One of the problems with a feature such as that, is that there are a number of types of trunks that customers can use. what works with one type, may not work properly with another. You can always suggest this in...http://3cx.ideascale.com/
