Dialing using outbound rule from missed calls
Discussion in '3CX Phone System - General' started by jschlatter, Apr 13, 2010.
  1. jschlatter
    Feb 9, 2010
    15
    How can I setup the 3cx system to dial missed calls using our outbound dial plan (9) when that does not show up on the caller id informaiton on my phone or the 3cx assistant? Is there a location that I can prepend all the caller IDs coming in with that outbound rule?
    11,283
    360
    Some ATA's will prepend a digit to inbound caller ID, I'm thinking of the SPA3102.
  3. mchristsen
    Mar 30, 2010
    26
    I had a similar problem dialing from the caller list from the Polycom 321 phone. I added an outbound dial rule that matched 10 digits, set my Gateway to dial out on and prepended a 1 (for US dialing). No "9" was needed.
    Michael.
  4. jschlatter
    Feb 9, 2010
    15
    Michael,
    Your solution worked like a charm... I must admit that I had a 'DOH' moment when I read it as it is so obvious that I should have thought of it before.
    Thanks a million!
    Jon
