Dialing with +
donbru01
Hi at all , i have Carrier that send me +39xxxxxxx Calling Number . When i want redialing missed call i must match +39
On 3CX Release 10 i manage outbound call routing +39 goto ISDN than striplead 3 digit and wok fine . Instead on release 11 i have this problem
30-gen-2013 15:43:19.706 Leg L:113.1[Extn] is terminated: Cause: BYE from PBX
30-gen-2013 15:43:19.706 [CM503008]: Call(C:113): Call is terminated
30-gen-2013 15:43:19.705 Leg L:113.2[EndCall] is terminated: Cause: BYE from 127.0.0.1:40600
30-gen-2013 15:43:13.603 [CM503007]: Call(C:113): EndCall:EndCall has joined, contact <sip:[email protected]:40600>
30-gen-2013 15:43:13.603 [CM503007]: Call(C:113): Extn:3755 has joined, contact <sip:[email protected]:57814>
30-gen-2013 15:43:13.602 L:113.2[EndCall] has joined to L:113.1[Extn]
30-gen-2013 15:43:13.451 [CM503025]: Call(C:113): Calling T:EndCall:EndCall@[Dev:sip:[email protected]:40600;rinstance=1d8bfd97e088979e] for L:113.1[Extn]
30-gen-2013 15:43:13.402 [CM503014]: Call(C:113): No known route from Extn:3755 to target: <sip:[email protected]:5060>
30-gen-2013 15:43:13.402 Call(C:113): from Extn:3755 to +392300313 doesn't match any outbound rule. No outbound rule could be selected.
30-gen-2013 15:43:13.402 [Flow] Target endpoint for +392300313 can not be built!
30-gen-2013 15:43:13.402 [CM503001]: Call(C:113): Incoming call from Extn:3755 to <sip:[email protected]:5060>
30-gen-2013 15:42:03.649 Leg L:112.2[EndCall] is terminated: Cause: BYE from PBX
30-gen-2013 15:42:03.648 [CM503008]: Call(C:112): Call is terminated
30-gen-2013 15:42:03.648 Leg L:112.1[Extn] is terminated: Cause: BYE from 10.0.42.123:57814
30-gen-2013 15:41:58.320 [CM503007]: Call(C:112): EndCall:EndCall has joined, contact <sip:[email protected]:40600>
30-gen-2013 15:41:58.320 [CM503007]: Call(C:112): Extn:3755 has joined, contact <sip:[email protected]:57814>
30-gen-2013 15:41:58.319 L:112.2[EndCall] has joined to L:112.1[Extn]
30-gen-2013 15:41:58.168 [CM503025]: Call(C:112): Calling T:EndCall:EndCall@[Dev:sip:[email protected]:40600;rinstance=1d8bfd97e088979e] for L:112.1[Extn]
30-gen-2013 15:41:58.119 [CM503014]: Call(C:112): No known route from Extn:3755 to target: <sip:[email protected]:5060>
30-gen-2013 15:41:58.119 Call(C:112): from Extn:3755 to +392300313 doesn't match any outbound rule. No outbound rule could be selected.
30-gen-2013 15:41:58.119 [Flow] Target endpoint for +392300313 can not be built!
30-gen-2013 15:41:58.118 [CM503001]: Call(C:112): Incoming call from Extn:3755 to <sip:[email protected]:5060>
30-gen-2013 15:41:49.265 Leg L:111.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.0.42.123:57814
30-gen-2013 15:41:49.264 [CM503003]: Call(C:111): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.0.42.123:57814
30-gen-2013 15:41:49.040 [CM503008]: Call(C:111): Call is terminated
any ideas?
3CX does not know what to do with the call, as dialled. Are you saying that version 11 does not know how to handle a + ?
You must have set e.164 section correctly, input '00' as prefix (if in Europe) and handle numbers starting with '00' the way you want into outbound rules. There was a post about MS Outlooks and the way it stores numbers.
In USA is more difficult, you must specify '011' as prefix, unless your provider is handling '00' correctly. For national number you need another rule stripping '011' from '0111' number.
Regards
In "Advanced Settings" i disabled the check box "remove if in same country"
In outbound rule i used in your case if 39 is dialed, strip off 2 digits and pre 00
I ignored the + and it works fine for me.
ok thanx soo much
Bruno
Get 3CX - Absolutely Free!
3CX
