- Joined
- Nov 23, 2016
- Messages
- 3
- Reaction score
- 0
I've not been able to pass dialnow dial plan settings to the phone using autoprovisioning. The handsets are Yealink T46G (latest firmware) on a new installation of 3CX v15, and I am simply trying to enable instant dialling for our internal numbers (3xx).
I copied the default Yealink T4x template to a custom version and tried the two methods I found in the guides and other posts on here - first by specifying the dialnow values in the # Dial Plan # section, and then by pointing the phone to DialNow.xml in the # Local Contact/DST Time/Dialnow Rule/Replace Rule # section.
In both cases the handset does not pick up the settings, confirmed by checking its event log which mentions neither. So I turned my attention to the .cfg file presented to it - I searched the file using notepad for "3xx" and "DialNow.xml" but neither are present, nor any other term for dialnow apart from the setting that controls the delay which is set to "1".
The handset is receiving other customisations from the template however.
It seems 3CX is just not building these sections into the cfg file, and so the handset is none the wiser.
Is there anything I can check/test? I have 60+ handsets to provision so would like to do this automatically.
Phil
Phil
