Dialogic DMG1008LSW AKA:1000 Media Gateway (FXO)
Discussion in '3CX Phone System - General' started by HPRG, Aug 16, 2012.
  1. HPRG
    May 11, 2012
    8
    Please somebody help me...please...
    Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    I cannot seem to get the DMG1008LSW gateway to "fully" function on the 3CX.
    I can get them both to communicate and respond with all kinds of "forbidden", "not authenticating", unknown user?, and a slew of other no's.
    However, I can see the logs on both devices showing that they are getting through to the other device and they speak the same language...they are just not saying the right stuff.
    Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
    I need help...
    thank you in advance!
    Laz
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    if you post here your logs from both sides and a whireshark capture when it tries to register with 3CX maybe someone can help you.
