Dialogic Intel D/480JCT-2T1 Card and SIP Gateway
Discussion in 'Windows' started by FarReachingSignal, Apr 15, 2010.
  1. FarReachingSignal
    Apr 15, 2010
    I've been given a Dialogic Intel D/480JCT-2T1 card to use to build a new VOIP system and being new to VOIP I decided to use the 3CX software but now need a SIP Gateway. Anyone know what SIP Gateway software I can use with the Dialogic Intel D/480JCT-2T1 card and can I run it on the same server as the 3CX software?
    Thanks!
    11,117
    329
    I think the question is...Is it supported by 3CX? http://www.3cx.com/support/voip-gateways.html
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,972
    281
    HI, as Leejor pointed out you need to have a supported gateway. The Dialogic is not on the list, you would have to use a supported gateway only....
  4. FarReachingSignal
    Apr 15, 2010
    Yeah, its a bonehead move not to read that first.
    Thanks for the answers.
