DID / DDI Edit Screen - Help setting up.
Discussion in '3CX Phone System - General' started by marcusjclifford, Apr 17, 2012.
  1. marcusjclifford
    Apr 17, 2012
    25
    I am new to the 3CX system, but have got most things working.
    I can make and receive calls internally (using extensions), and externally I can make outgoing calls to the public phone network.
    I however have problems with receiving calls from outside - for this test I want calls made to specific phone number to ring an extension.
    Using VOIPTalk as my provided (as it is free while setting up) - I got the following information from them:
    Current number: 08435325599
    Current status: 08435325599 -> SIP/DDI-844278261-08435325599@voiptalk.org
    I have set to option to: Select a Configuration Option: Route to SIP PBX
    On the 3CX Admin screen what information should I put in the "Add DID" screen?
    DID/DDI Name:
    Inbound Rule Type:
    DID/DDI number / Mask:
    Router is configured as per instructions:
    UDP 9000 - 9015 9000 - 9015
    TCP 5060 - 5060 5060 - 5060
    UDP 5060 - 5060 5060 - 5060
    all port forward to my 3CX Server, on which the firewall is turned off.
    Thanks in advance for any help, and if you need any more info let me know.
    Marcus
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Try this as a start -
    http://www.3cx.com/forums/display-the-name-associated-with-a-did-when-ringing-queue-28821.html
  3. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Also try with this two videos:
    http://www.youtube.com/watch?v=MHes5p4PkWo
    http://www.youtube.com/watch?v=7kKFaquTTNs
