Solved DID for Fax?
Discussion in '3CX Phone System - General' started by msnyder, Jul 27, 2017.
  1. msnyder
    Jul 20, 2017
    24
  2. tim942
    Jul 30, 2015
    68
    6
    I typically create the DID in the gateway settings, and then assign it in the Inbound rules. Assigning via the device has been buggy for me.
  3. msnyder
    Jul 20, 2017
    24
    My fax extensions don't show up under Inbound Rules...
  4. tim942
    Jul 30, 2015
    68
    6
    Lets take a step back, did you setup your phone system or did you have a partner/installer do it?
    When you go to your Gateway Settings, do you have any entries under the DID tab? I cheat and use mostly wildcards (so if I have a list of numbers where only the last 4 digits are expected to be unique, i put *4200, *6000, *6001, etc.).
    These numbers will now appear in "Inbound Rules", from there you can specify where they go (and give them appropriate descriptions, I use the full phone number as the name).
  5. msnyder
    Jul 20, 2017
    24
    I set it up.
    I use SIP trunks, not a gateway, but yes, I have my DIDs there.
    The DID do appear in Inbound Rules, but the fax extensions do not.
  6. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    Under inbound rules for "office hours" and "outside office hours" choose "send fax to" and it will show your FAX extensions as well as extensions that have email addresses on them.
    Selecting a FAX extension sends the call to the machine. Selecting a regular extension with an email address 3cx receives the fax, makes it a pdf and sends it via email to the email address of the extension.
  7. tim942
    Jul 30, 2015
    68
    6
    Sorry, my gateway is now listed as a SIP Trunk too (I hate when things are relabled).
    In your "Inbound Rules", do you have the ability to set a destination for calls?
  8. msnyder
    Jul 20, 2017
    24
    That works! Thanks!
