DID inbound target
Discussion in '3CX Phone System - General' started by brammeke0207, Mar 5, 2011.
  1. brammeke0207
    Feb 2, 2011
    11:52:03.628 Looking for inbound target: called=; caller=0474509088
    11:52:03.628 [CM500002]: Info on incoming INVITE:
    INVITE sip:050950960@178.119.48.244 SIP/2.0
    Via: SIP/2.0/UDP 85.119.188.31:5060;branch=z9hG4bK111c9e54;rport=5060
    Max-Forwards: 70
    Contact: <sip:0474509088@85.119.188.31>
    To: <sip:050950960@178.119.48.244>
    From: "0474509088"<sip:0474509088@85.119.188.31>;tag=as7cf98f2b
    Call-ID: 53116837081274832a5796b72d753cac@85.119.188.31
    CSeq: 102 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    Date: Sat, 05 Mar 2011 10:52:04 GMT
    Supported: replaces
    User-Agent: Integrics Enswitch
    Content-Length: 0
    Diversion: <sip:050950960@ast2>
    Here my DID is clearly before the destination IP Address, "INVITE SIP:DID@IP:5060;"
    In the Provider Source ID tab:
    I have checked the "Source indentification by DID" box,
    Selected: "Request Line URI : User Part" as the "SIP Field containing DID numbers",
    added masks for the DID's such as:
    050950960
    050950961
    Then added the DID's to the DID tab in the Edit VOIP Provider.
    Calls still only route to the destination setup under the "Edit VOIP Provider" screen, no matter the routing on the spific DID's further down the tree.
    greetz,
    Brammeke0207
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    did you select add masks or add dids?
    My preferred method (and i honestly dont know if it makes a difference in 3cx) is that if it is a did that is being sent as in your case then i add the dids to the did tab, then go to the source id tab and click on DIDs and select all.
    If the provider doesnt always send a did (e.g sometimes they send the did, sometimes there is a 1 in front for country code and sometimes a + sign then i click add masks and add a wildcard *
    I am guessing (pure guesswork) that when you add a mask 3cx does a slighly different matching and are expecting a wildcard in there.
    So try that as you said you added a mask. The rest looks correct.
    Of course Stepan will now come along and tell me I am wrong and it makes no difference which button you add :)
