DID Logic 3CX DID
Discussion in '3CX Phone System - General' started by seanc, Aug 7, 2015.
  1. seanc
    May 25, 2015
    25
    never used DID Logic before.
    I purchased a 03 UK-wide national DID number from DID Logic.
    I created a SIP account on DID Logic and forwarded the 03 UK-wide national number to SIP Device.
    (really not sure if i need to forward to SIP device or SIP URI)
    Is that all i need to do in DID Logic?
    next step, i added a new VOIP Provider in 3CX using the built in DID Logic template.
    the built in DIDLogic template leaves the OUTBOUND PROXY blank - is this correct?
    My trunk is registered in 3CX :)
    i have an OUTBOUND rule with a simple 9 for prefix (im hoping if i press 9 then all calls will route over didlogic)
    when i dial out i see this message in the log file;
    07-Aug-2015 12:26:23.851 Leg L:556.2[Line:10001>>99975378] is terminated: Cause: 404 No destination/INVITE from 178.63.143.236:5060
    any help appreciated.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    Quick question, on the outbound with prefix 9 you are stripping the first 1 digit - to remove the 9 before dialling
  3. seanc
    May 25, 2015
    25
    no i wasnt, but i strip 1 digit now.
    07-Aug-2015 13:28:34.622 Leg L:566.1[Extn] is terminated: Cause: BYE from PBX
    07-Aug-2015 13:28:34.581 [CM503020]: Call(C:566): Normal call termination. Call originator: Extn:10. Reason: Not found
    07-Aug-2015 13:28:34.581 Leg L:566.2[Line:10001>>99975371] is terminated: Cause: 404 No destination/INVITE from 178.63.143.236:5060
    07-Aug-2015 13:28:34.581 L:566.1[Extn] failed to reach Line:10001>>99975371, reason Not Found
    07-Aug-2015 13:28:34.581 Call to T:Line:10001>>99975371@[Dev:sip:00111@sip.didlogic.net:5060] from L:566.1[Extn] failed, cause: Cause: 404 No destination/INVITE from 178.63.143.236:5060
    07-Aug-2015 13:28:34.581 [CM503003]: Call(C:566): Call to <sip:99975371@sip.didlogic.net:5060> has failed; Cause: 404 No destination/INVITE from 178.63.143.236:5060
  4. seanc
    May 25, 2015
    25
    solved -
    i was trying to call a local mobile number through a UK DID - so i needed to add my country code
  5. Saqqara
    Mar 12, 2014
    1,252
    203
    What number are you dialling on the phone, as it appears the system is trying to dial 99975371
    From previous post, the number should start will 0 - reason it works with country code.
  6. seanc
    May 25, 2015
    25
    i was dialing 99975371
    that is a local cypriot mobile number - my DID is a UK number, so i needed to put the country code.
    thanks for the help.
  7. Saqqara
    Mar 12, 2014
    1,252
    203
    That explains it, calling an international number
    Glad it is now working
  8. Ruy
    Ruy
    Mar 23, 2017
    8
    Hello guys. Can anyone help with this?
    I have a Didlogic number from SP Brazil (5511-4858-XXXX where 55 is the country code and 11 is the city/estate code). Why do I have to dial "5511" before every local number (the only way the system works). Is there a way to avoid having to force my users dial the country and city code when they are trying to reach local numbers?
    2nd question (inbound calls):
    When I try to dial or trunk number (+55 11 4858-XXXX) from another phone I get a: "one moment please we are calling your party" "we are still try to connect your call" then "we are sorry your call cannot be completed as dialed" and lastly a msg from a brazilian local company saying the number does not exist.
