DID name to caller ID
Discussion in '3CX Phone System - General' started by bell, Mar 19, 2015.
  1. bell
    Jul 30, 2014
    23
    On the option "Inbound name to caller ID", is there any way to choose which info is displayed. All I want is the DID that the call came in on and then the normal caller ID to follow. I don't want it to show which ring group etc as well.
  2. bell
    Jul 30, 2014
    23
    Am I even going about this the right way, what im trying to achieve is get the name of the voip provider before the caller ID. Ill have two voip providers for two different areas and need to know which number they called.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Update the DId name to be the provider ... And change the ring group to be empty name. I don't think you can choose which info to show if you turn pretend to On.
  4. bell
    Jul 30, 2014
    23
    How do you edit the name of the SIP provider? If I search around there are some old posts requesting it as a feature but no way to do it.
  5. bell
    Jul 30, 2014
    23
    Well it looks like I don't have to rename it as that name never shows up, what I have tested an seams to work is to name the ring groups the name of the line I wish to display, then route the different lines to go to those ring groups, it displays exactly what I need.
